Old 08-09-2014, 08:17 PM   #1
desertnick69
desertnick69's Avatar
Rear suspension swap
I changed out frames on my 69 C-20 due to an accident. now that I have the rear trailing arm suspension almost back together, is there any particular order it should be put back together? I thought i had read some where to install springs to frame, than trailing arms, and let the rear end hang, then attach the T/A's to the crossmember?
Thanks Nick
desertnick69 is offline   Reply With Quote
Old 08-09-2014, 09:32 PM   #2
hugger6933
Re: Rear suspension swap
Ought to work fine that way Nick. Good luck. Jim
hugger6933 is offline   Reply With Quote
Old 08-10-2014, 01:05 PM   #3
desertnick69
Thanks, Like i said I had read on some post that you should do the rear section put in the crossmember then hook up the trailing arms. ant idea of the torque on the bolts on the trailing arms to the crossmember?
