![]() Join Date: Jan 2014
Engine Degrease and Cleaning
I will be attempting to degrease and clean up my engine bay for the first time tomorrow morning. Any tips or tricks? Dos and Don'ts? Anything not to get wet? Anything not to get cleaner on? Anything that needs to be covered? I have a pressure washer too. I also purchased some "Super Clean" which I was told is like "Simple Green". I'm still a total newbie and learning as I go along. Is it weird that I'm really excited to get started?
I'm looking to replace the air filter with a K&N Filter and new top too. I'm tired of looking at what's on top right now. ![]() ![]() |
Re: Engine Degrease and Cleaning
Get rid of the clear plastic gas filter. those are a real fire hazard.
Should just be 2 hose clamps and done. I'd replace the clamps at the same time, unless they look good/new.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
One other item- Be careful with Castrol super clean at full strength. It will etch any unprotected aluminum surface, and strip wax off of paint. It is awesome stuff to use, though.
Just don't breathe in the mist!
Get some carb cleaner, stuff a rag in the throttle opening and wash the carb off with the carb cleaner, then put a bag over it to keep the water out. Put a bag over the distibutor cap. Spray it down with you degreaser let it soak in for a while. Protect your paint on your fenders and cowl with towels. I have used gunk and regular old oven degreaser. Pressure wash it off. Uncover everything and get it started up. Good luck
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
Not wierd at all...you re a motorhead, and we get excited when we get to do mechanical stuff
![]() When you replace the fuel filter, if it is a plastic type don t use worm drive clamps. They can squish the inlet and outlet closed. Just use spring type clamps (OEM) Use as much steel fuel line as you can make up, or go to the junkyard and get a used one Good Luck, ^^^^^^^^^and all great advice, pay attention young grasshopper ![]()
A new steel filter should go on easy. Just unscrew the hose clamps or squeeze the spring type clamps on your present filter. Use new clamps. Check the present fuel hose and make sure it isn't deteriorating. Might be worth your while to get a couple more feet of hose and replace whats there. Not sure of the size 3/8ths? 5/16ths? The inlet side of the fuel filter on my bench is 3/8ths. Best bet is to pull of the present filter and match it up at the auto parts store. Personally I don't like to have much rubber fuel line. You might want to consider replacing what you can with steel
I've used Gunk brand engine degreaser with success in the past. You can get it at Walmart. Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
So was the original fuel filter suppose to be installed between the fuel pump and fuel tank? Was it originally installed maybe along the frame rails on these K5s?
There where some that did have a canister filter mounted along the frame rail. Most have a filter sock on the inlet inside the tank. and the sintered bronze or paper element inside the carb inlet. Putting rubber hose and a filter between the fuel pump & carb is a fire hazard. The hose becomes old and the plastic and glass see through filters can burst. Ive never seen a GM factory installed filter attached with rubber hose installed between the fuel pump & carb. a solid steel line is what came from the factory on trucks. I cut the rubber line on the inlet side of the fuel pump and install a wix steel cased filter at that location. I also use the factory sintered bronze filter in the carb inlet.
Found this under a rattle can paint job on my driver's wheel well? Super Clean strips rattle can paint come to find out. LOL. Does this mean it's an original wheel well. The sticker looks pretty well preserved. Wondering if it's a reproduction?
Finding surface rust covered by rattle can. Should I sand it off and re-paint? ![]() |
Moderator
![]() Join Date: May 2007
POR Marine clean is the best degreaser I have ever used. I suspect it is bilge cleaner. Makes simple green look like water.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
