Driveline part help
I have this plate after where the ujoint is mounted that spins and makes a horrible racket that I would like to get ride of the noise I got some pictures of the plate. Just need some help I'm a newbie haha
Chrome makes everything run better!!! ![]() |
Re: Driveline part help
That's a dust cap for your seal. It should not be loose but you do need to have one. See all that crud. It keeps that crud from your seal.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
itll be abit of a paint to remove it, but its not that important. but id probably clean it up wiht some brake cleaner and then some rtv to glue it to the pinion so it doens tmake noises anymore
blood type; Retumbo
that piece should be pressed onto the yoke. I can see shiney metal between yoke and the plate.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Some Rtv gasket maker will work to put it on to the pinion?
Can anyone post any pictures of there's so I can see what it is exactly suppose to look like I would really appreciate it
blood type; Retumbo
the bell/flare shaped sheet metal piece is in there the right direction, just not far enough towards the U joint. It should be up against the shoulder of the yoke. Not on the pinion. It is pressed on but a few carefull taps with a small hammer and punch will do the trick.
Do you have a picture of what on is suppose to look like I would really appreciate it
It's so worn down next to the ujoint it can't be hammered back into place
blood type; Retumbo
Cover shipping both ways and I will fix it for free
I appreciate the effort I think I fixed it i had some all purpose cement and primer and I used that and it seems like it is working thank you though
blood type; Retumbo
the offer stands if you EVER change your mind
Well thank you I appreciate it haha
