Decreasing Turning Radius?
Has anyone decreased their turning radius? My truck has an Ididit steering column. Its radius right now is ok, but parking can be a bit of a pain. As my DD, I definitely wouldn't mind a smaller radius. Thoughts/suggestions??
Sean |
![]() Join Date: Aug 2011
Re: Decreasing Turning Radius?
And all this time I thought it was just me that had to back up and turn a few times to park....and mines a short bed.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
#3 | |
Cut my bump stop out when lowered the on 66 3/4 lbw, now my tires hit frame but it can turn real tight, backing up it is like folk lift .
#5 | |
![]() I drive a 35' 13 ton truck all day long and that's all the fun I can stand for the day.
doesn't the stops on the spindles control the turn radius.
Never Ending Projects
Yes, the spindles have a point that contacts with the lower control arm bump/steering stops. Unless you remove this stop off the lower control arm, you will not get any more steering angle.
The column has nothing to do with steering angle.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Left foot brake, right foot gas! I have come in hot and power slid into spot next buddies car.
Quick ratio box or rack will do. My open knuckle 56 Willeys Jeep turned tighter than car with rack.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#9 | |
Sean |
