08-13-2014, 07:36 PM | #1 |
what i have, what i want.....
72 gmc 3500 4 speed granny gear..... I want a 5 speed granny gear.... is there a 5 speed that bolts up to the bell I already have? if not is there a bolt up 5 speed that doesn't use a slave setup? thanks, steve
ive been searching but im not finding.... |
08-13-2014, 08:38 PM | #2 |
Re: what i have, what i want.....
Do you have an allergy to the slave type system? Is there some reason to not use it that you don't want to share that is cool just say so, but I think the best route is gonna be to go with the NV4500 and the slave.
Now I am almost certain that what you want has been made. I was planning [and still kinda am] a dually C-60 and was wanting a 5 speed at one time. I had run across some trans I don't remember what it was from but it had the removable bellhousing I am almost positive. I think it was from a late 80's early 90's C3500 truck |
08-13-2014, 09:56 PM | #3 |
no problem with hydrolic setups.. just thought it might be easier to use what was already in the truck rather than having to do fab work....unless its all pretty much bolt in....?
does the nv4500 need to be brand specific or do they swap from one to the other...ive really not messed with the hd stuff much so im not up to par with what does and doesn't go with what....id appreciate any info you can give to get me going in the right direction.... thanks. |
