Old 08-13-2014, 08:14 PM   #1
Mv7fd
front end hop
when i'm going down the road i get a vibration or hop I'm not really sure what it is. it's not lifted or anything anyone have any ideas
Mv7fd is offline   Reply With Quote
Old 08-13-2014, 08:26 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: front end hop
Balance your tires.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-13-2014, 09:44 PM   #3
Keith Seymore
Keith Seymore's Avatar
Re: front end hop
Need more detail.
What speeds? Does it get better or worse as you go faster?
Do you feel it in the steering wheel? in the seat? Is it something you feel only, or do you hear something too?
Can you do it with the truck stopped, in neutral, by revving the engine? What if you coast at that speed in neutral?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-13-2014, 09:51 PM   #4
Mv7fd
Re: front end hop
i feel it in the steering wheel and in the seat a little. it does get a little better with speed.
Old 08-14-2014, 04:03 AM   #5
Burmanater
Re: front end hop
Make sure you're front calipers are releasing also. A slight drag will over a long distance drive will get the rotor hot and out of shape.
I would look at your wheels and tires first though and check for broken belts in the tires then have them balanced.
Burmanater is offline   Reply With Quote
Old 08-14-2014, 06:34 PM   #6
Mv7fd
Re: front end hop
found my problem passenger side tie rod end is really bad
