08-14-2014, 08:50 PM | #1 |
does someone make an original style starter for a 168 tooth flywheel?
I'm installing a Ramjet 350 into my '65 C10. The Ramjet has a one piece rear seal so it uses a special flywheel which is 168 tooth. Does someone make an original stye starter, but for a 168 tooth flywheel, or will I have to change my flywheel to a 153 tooth?
08-14-2014, 09:00 PM | #2 |
Re: does someone make an original style starter for a 168 tooth flywheel?
or better yet... any issues with using my block mounted mini starter that's already on my ramjet with the factory bell housing that normally would use a bell housing mounted starter?
08-14-2014, 09:13 PM | #3 | ||
http://www.novak-adapt.com/knowledge...shift_info.htm |
