08-17-2014, 08:39 PM | #1 |
72 K5 blazer factory speakers
I think the factory speaker was under the dash near the tranny hump or behind the pass. seat in the side panel. I would like to mount mine under the dash if I could find a factory mount. Can anybody tell me if I am correct about the location of the speaker and if so where can I find one. If anyone has pictures that would be nice!
08-17-2014, 08:54 PM | #2 |
Carpe manana
Re: 72 K5 blazer factory speakers
Some K5s had the speaker mounted to the dash just below the AC or heater controls but other K5s (including mine) had speakers mounted just like the pickups, tucked up under the dash. Do you have speaker holes on the upper metal portion of your dash between the pad and the windshield? If not, you need the under dash speaker - a hard piece to scare up.
Relevant threads: http://67-72chevytrucks.com/vboard/s...ad.php?t=48071 http://67-72chevytrucks.com/vboard/s...d.php?t=431646 There are two style of mounting brackets: with or without threads IIRC - seems to relate to AC vs. non-AC K5's.
08-18-2014, 11:32 AM | #3 |
A couple more threads for you....
http://67-72chevytrucks.com/vboard/s...d.php?t=213085 http://67-72chevytrucks.com/vboard/s...d.php?t=522444 |
08-18-2014, 09:03 PM | #4 |
Thanks Deadhead and Jim. That helps a lot
08-19-2014, 12:47 PM | #5 |
I think you can buy both style speakers aftermarket. Just have to figure out wich style you have.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
