Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-17-2014, 10:34 PM   #1
3QTRTONS
3QTRTONS's Avatar
Energy Suspension Master Set 4x4 73-80 3.18104g
Bought for a project that isn't happening.... $150.00 Shipped in the lower 48
HYPER - FLEX SYSTEM PERFORMANCE POLYURETHANE BUSHING KIT FOR 73-80 CHEVY GMC 4WD
New in the box; opened only for photos & inspection.
These sets usually sell for $210.00 shipped. Save $60 by buying these!!!
FREE U.P.S. Shipping in the US ...... 18# box.
Brand:Energy Suspension
Manufacturer's Part Number:3-18104G
Part Type:Bushing Kits
Product Line:Energy Suspension Hyperflex Bushing Kits
Summit Racing Part Number:ENS-3-18104G
UPC:703639277323
Bushing Material:Polyurethane
Bushing Color:Black
Front Control Arm Bushings Included:No
Rear Control Arm Bushings Included:No
Front Sway Bar Bushings Included:Yes
Front Sway Bar Bushings Greasable:No
Rear Sway Bar Bushings Included:No
Rear Sway Bar Bushings Greasable:No
Front Sway Bar End Links Included:No
Rear Sway Bar End Links Included:No
Steering Rack Bushings Included:No
Body Mounts Included:Yes
Radius Arm Bushings Included:No
Front Strut Rod Bushings Included:No
Rear Strut Rod Bushings Included:No
C-Bushings Included:No
Axle Pivot Bushings Included:No
Front Track Arm Bushings Included:No
Rear Track Arm Bushings Included:No
Front Coil Spring Isolators Included:No
Rear Coil Spring Isolators Included:No
Front Leaf Spring Bushings Included:Yes
Rear Leaf Spring Bushings Included:Yes
Front Leaf Spring Shackle Bushing Included:Yes
Rear Leaf Spring Shackle Bushings Included:Yes
Transmission Shift Stabilizers Included:No
Transmission Mount Included:Yes
Transmission Crossmember to Frame Bushing Included:No
Rear Trailing Arm Bushings Included:No
Torque Arm Mounts Included:No
Strut Tower Bushings Included:No
Rear Panhard Bar Bushings Included:No
Rear Leaf Spring Pads Included:No
Rear Spring Cushions Included:No
Front Shock Bushings Included:No
Rear Shock Bushings Included:No
Rear Subframe Bushings Included:No
Differential Pinion Bushings Included:No
Rear Differential Carrier Bushings Included:No
Ball Joint Dust Boots Included:Yes
Tie Rod End Dust Boots Included:Yes
Steering Coupler Bushings Included:No
Rear Overload Spring Snubbers Included:No
Rear Watts Link Bushings Included:No
Front Axle Bump Stops Included:No
Transmission Torque Arm Bushings Included:No
Motor Mounts Included:No
Bar End Grommets Included:No
Lower Control Arm Bump Stops Included:No
Front Bump Stops Included:No
Rear Bump Stops Included:No
Power Steering Ram Bushings Included:No
Differential Carrier Mustache Bar Bushing Included:No
Quantity:Sold as a kit.
1969 ES5500 B E A S T 1976 K20 Suburban
1983 C10 'farm truck' 1984 K10 Suburban
1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 09-30-2014, 09:13 AM   #2
3QTRTONS
3QTRTONS's Avatar
Re: Energy Suspension Master Set 4x4 73-80 3.18104g
SOLD, Thanks...........
1988 V30 Fire Truck
