Old 08-18-2014, 12:06 PM   #1
SteveMiller
SteveMiller's Avatar
lmc LED taillight install (blinker??)
I purchased the lmc LED taillights for my 61GMC. I already have an Ididit column and planned to replace all the factory wiring. BUt the new taillights only have a brake, and a running light wire. No provision for blinker. How has this been handled by others?
Also, I installed LED front parking lights in the hood, and they are single filament. I want to use them as running lights AND blinkers.
It seems the only solution is to run two trailer convertors. Just hoping others could post their experience and solution.
SteveMiller is offline   Reply With Quote
Old 08-18-2014, 12:38 PM   #2
61K10
61K10's Avatar
Re: lmc LED taillight install (blinker??)
SteveM--your lights only have two wires, running lights and brake and turn
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-18-2014, 01:05 PM   #3
SteveMiller
So does everyone just run A trailer type tail light converter then?
Old 08-18-2014, 01:06 PM   #4
SteveMiller
Maybe I'm missing something. I don't have my original rear harness anymore. Is there something within the flasher circuit that already handled this for me and I just don't know what?
But yes. My LMC taillights only have two wires as you stated
Old 08-18-2014, 01:39 PM   #5
61K10
61K10's Avatar
the turn sig/switch in your column controls the blinkers
1961 chevy K10
Old 08-18-2014, 01:46 PM   #6
SteveMiller
So is this basically what happens for your trucks then too?
Essentially it seems the signal switch diverts power through the flasher for the bulb in question while keeping the other brake light on.
Now, if I can figure out a way to combine the hood mounted parking lights into this figure.
Old 08-18-2014, 02:19 PM   #7
Clyde65
Clyde65's Avatar
Your front "marker" lights are supposed to go out when your headlights are turned on.
Is this what your referring to?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-18-2014, 02:55 PM   #8
61K10
61K10's Avatar
Steve there is a way to use them as running lights. you run a jumper in your light switch. sorry don't remember the process. maybe in the electrical faq's or somebody will chime in.
1961 chevy K10
Old 08-18-2014, 03:32 PM   #9
Lugnutz65
Lugnutz65's Avatar
EDIT: I had the link below saved on my computer because I planned to use the hood lights as markers when my headlights were on. But now it looks like the links in post #3 are broken. Rats.
See post #3 in the link below. It has 2 different links for different year trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=577029
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
