Old 08-18-2014, 07:06 PM   #1
Kennuck
Kennuck's Avatar
Stock Rad is 3 row ok
I have searched and read extensively but haven't found the answer. Has anyone used a Stock copper/brass 3 row rad on their LS conversions. I know lots of guys used the stock rad, but its not real clear how many rows everyone used? I plan on running the LM7 engine driven fan and stock SBC shroud.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 08-18-2014, 07:15 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Stock Rad is 3 row ok
Originally Posted by Kennuck View Post
I have searched and read extensively but haven't found the answer. Has anyone used a Stock copper/brass 3 row rad on their LS conversions. I plan on running the LM7 engine driven fan and stock SBC shroud.
I have a stock 3-4 row in mine right now.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-18-2014, 07:50 PM   #3
Kennuck
Kennuck's Avatar
Andy thanks for the quick reply, what do you mean by 3-4 row? When I look inside the cap on mine there are only 3 rows of tubes visible. Looks like there is room for another row in the end tanks. Its in good shape and didn't want to re-core if I don't have to.
Ken
1970 Short Wide
Vintage Air
Old 08-18-2014, 08:48 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Stock Rad is 3 row ok
I don't remember which one I have. I think it maybe a 4 row. Can't look at it right now to tell.
Old 08-19-2014, 01:24 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I'm running a stock 4 row with dual e-fans and it ranges from 180*-190* and never rises above that. My guess is you'd be OK with a 3 row as long as you don't have a/c...and don't plan on hauling/towing heavy loads with it.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-22-2014, 05:37 AM   #6
Xeen
Xeen's Avatar
A 3 row should be just fine vortecs are designed to run hotter than a gen 1 block by design.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-24-2014, 12:17 AM   #7
solidaxel
solidaxel's Avatar
A 3 row copper and brass here in the desert with a puller fan and in the hot part of the day with the A/C on it reads 195.8*, this is a new stock replacement rad for my 78 5.3 conversion
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
