Any ever use this?
Has anyone ever used this on their work?
Can you review it? http://www.mrochem.com/BlackStar-Rus...rter_p_16.html or even this stuff? http://www.mrochem.com/Bust-da-Rust-Rust-Away_p_89.html With all the rust we find its advertisements would be a God Sent. |
Senior Enthusiast
Re: Any ever use this?
Sorry never heard of it.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
I ordered some of both I posted here... "IF" its half of whats claimed I'll be happy... I own a tub grinder for the Nursery I have here,,, rust is always a issue with that thing..
#4 | |
I tried a similar product under a different name. Sprays on or paints on and is easy to use. However, it only converts the rust that's on top. Take a knife and scrape the surface and you will find that rust is still beneath the top black coating. I'd use it on a trailer or other outdoor project that needed a little help and protection. It covers the rust with a nice looking black coating, but it gives you a false sense that you have correctly treated the rust. It just ain't so!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#5 | |
My truck roof was pretty rusty and I used a greenish prep on it, forget the name though. I followed that with epoxy primer and no rust two years later sitting outside in houston. You need to get as much of the metal bright and shiny as you can, then treat it. Look at the roof of this camaro, it was pitted pretty badly. This picture is after I sanded it a lot, but not done yet: ![]() ![]() Here it is prepped with phosphoric acid stuff. I actually treated it and sanded it some more a few times: ![]() Here it is ready for primer: ![]() Here it is primed, note how more paint delaminated on the pillar posts just from pulling the masking tape off in Oct 2012: ![]() It still looks that good, but it is starting to get a bit chalky. That's almost two years of sitting in the houston sun and rain. I would sand and reprime before putting real paint on it. Here's my truck after I primed it two years ago: ![]() Here it is today, no rust at all: ![]()
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster Last edited by Anthony Fremont; 08-19-2014 at 04:35 PM. |
IMO, current technology shows that properly sanding to remove rust, then chemically treating it with phosphates, and then sealing it with epoxy promer is the way to go. I bet that greenish fluid Fremont used is Picklex. It's a phosphate and is expensive and not compatible with some primers. Not worth the hassle. For small jobs where you just want to touch up a small spot or two, the rust converter is easy and will do the job. It's just not my choice if I plan to spend good money on a paint job.
Why does pic 4 of the blue car's roof still have a rust color to the roof? I'll bet the rust will be back shortly.
Those rust converters only convert the top layer of rust. You need to apply it, sand, apply, sand, til the rust is gone. You can't just paint it on and see things turn black and say the rust is gone. Immersing a part overnight works if you can put the part in a bucket. |
#8 | |
Read that post again. He says that there's no rust coming through the blue car roof after 2 years. He used epoxy, not rust converter. I agree with you, rust converter makes a skin cover over the rust, but the rust underneath remains. Immersing in chemicals is good too, but can you immerse your truck roof?
#9 | |
I find that the acid helps to get more rust off than sanding alone. It seems to loosen and "lift" any significant rust so that it would sand off better. The acid makes the steel a gray color and turns the rust black. After two years of only epoxy primer, there is still no bubbling or anything showing up. I like the acid stuff. I'm certainly no expert at paint, but I did have good luck with the green stuff. About 20 years ago I did the roof of an old impala and I used actual Naval Jelly, which was a pink gel that would eat the skin off your hands. The green stuff I used on the truck and IROC was runny like water and didn't burn my hands. I might have used rubber gloves anyway, I don't recall though. I do remember it was much weaker than the Naval Jelly was. The naval jelly penetrated a lot better. It took almost 10 years before rust started showing back up, and I never painted it, only epoxy primer.
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster Last edited by Anthony Fremont; 08-19-2014 at 10:57 PM. |
#10 | |
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster Last edited by Anthony Fremont; 08-19-2014 at 10:53 PM. |
