Old 08-20-2014, 09:12 AM   #1
Jimal
Jimal's Avatar
Parking brake return spring
This is one of the fiddly little things I want to fix before putting the bed on. After overhauling the brakes on my K-10, I'm happy to report the parking brake now works on my truck. Or at least it holds the truck when on. As you can see, I'm missing the return spring. I'm sure something off the shelf should work if I make up a bracket to attache to the lever and drill a hole in the frame. Any suggestions on the size (length, diameter) of that spring?
Jimal is offline   Reply With Quote
Old 08-20-2014, 12:27 PM   #2
WhippinSaw
WhippinSaw's Avatar
Re: Parking brake return spring
On my 63 its a Spring and a rod, the spring was about 12 inches long and tough to put on.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 08-20-2014, 01:51 PM   #3
pimpston65
pimpston65's Avatar
my setup is a bit different then urs, i just finished mine
pimpston65 is offline   Reply With Quote
Old 08-20-2014, 08:48 PM   #4
bhc41051
bhc41051's Avatar
Jimal, I have an extra one, PM me with your address and I'll send it your way
bhc41051 is offline   Reply With Quote
Old 08-20-2014, 09:13 PM   #5
bhc41051
bhc41051's Avatar
Jimal, Here's a photo of the spring attachment piece I think you're missing. The rusty spring came with the truck. I had Century Spring make one for me but to make their minimum order I had to order six
Old 08-22-2014, 12:23 PM   #6
KVB
Jimal, Is this a short bed truck?
It looks like the parking brake bracket is attached to the crossmember that supports the carrier bearing. Is that right?
In the other photos, the bracket looks like it is supported off of the transmission crossmember.
Is there a dedicated crossmember for the bracket?
Ken
KVB is offline   Reply With Quote
Old 08-22-2014, 02:20 PM   #7
Jimal
Jimal's Avatar
Ken
The truck is a shortbed. I'd have to have the truck in front of me in order to answer your questions.
Old 03-16-2016, 09:51 PM   #8
Dad&Son61
Does anyone have a pic for a 61 c10 swb parking brake assembly?
Dad&Son61 is offline   Reply With Quote
