My '66 Suburban
Picked up this beauty on sunday. This will be my first car to fix up and I love it. Needs some work but pretty excited about its potential. Has a "running" 350 in it with an auto 350 trans. Odometer says 83,000 but it probably has more. Let me know what y'all think and any suggestions on what to do with it. I own an Antique business so I plan on just getting it running good, painting my logo on the doors, lowering it a tad and put smoothies on it. It'll be a daily driver for me eventually.
Re: My '66 Suburban
More pics...
Re: My '66 Suburban
Engine bay
Re: My '66 Suburban
A real beauty you have there.
I wish I could find one. |
![]() Join Date: Sep 2011
Re: My '66 Suburban
Looking good you have a lot of potential there.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Re: My '66 Suburban
Thanks guys!
Re: My '66 Suburban
I would bet the mileage is legit. Nice buy.
Jon S 1966 GMC Suburban 305 V6 Las Vegas NV |
Re: My '66 Suburban
You can't go wrong with a BURB!!! j
Re: My '66 Suburban
I have to get it running good again first. But how would y'all recommend lowering it a little without notching the frame or doing any serious modifying. Any suggestions are appreciated!
Re: My '66 Suburban
Mine had 14" rims and low-profile tires when I got it. That lowers it a bit. I'm going back to stock height, but that's just me.
Re: My '66 Suburban
MIne has 1 1/2 inch lower blocks in the rear. j
Never Ending Projects
Re: My '66 Suburban
CPP makes a Heavy Duty 4" dropped spring that is for 'burbs and panels. I haven't got mine on the road but I bought a set. The coil diameter is a little thicker than the stock ones and much thicker than most rear dropped springs.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: My '66 Suburban
Awesome I will check those out. Thanks!
Re: My '66 Suburban
Got the engine started today! Now need to replace all fluids, replace a couple break lines, and put new power steering rag joint on. After that's it's road worthy!
#15 |
![]() Join Date: Jun 2013
Re: My '66 Suburban
Right on!!!!! Great Burb, Love it Congratulations. I just picked up my 66 about a month ago, well actually bought for my son for his 15 B Day, doing a little work on it together so it will be ready for him to drive when he's 16
Ours has a 3" drop coil in front and 2" drop coil in the rear but I think I'm going to change it to stock coils all the way around and a 2.5 drop spindle in front and 1" drop block in the rear, this should make the ride a bit softer as drop coils are pretty stiff Enjoy your Suburban !!!!! |
#16 | |
Re: My '66 Suburban
Thanks! Post pics of yours if you get a chance? |
#17 |
Re: My '66 Suburban
Got the engine running yesterday but was over heating. Replaced all fluids . Also Replaced radiator cap and thermostat. Now it is running nice and cool! Seems to run good for sitting so long. Running a bit rich but still good. Put new brake hoses on front and bleed brakes. Putting new steering coupler on tommorow and ready for a test drive.
#18 |
Re: My '66 Suburban
CPP has a 2/4 drop kit with springo and shocks. I just put it on my 66. Detroit steel wheels has some awesome steel smoothies. I just ordered a set for mine. They are 20 by 8s
#19 |
Re: My '66 Suburban
#20 |
Re: My '66 Suburban
#21 |
Re: My '66 Suburban
Those parts look to be in good shape to match your burb
#22 |
Re: My '66 Suburban
#23 |
Re: My '66 Suburban
Consider drop spindles with discs for the front of your rig! I have a '66 Truck with the 2.5" drop spindles up front and 3" drop springs in the back, came out perfect and it stops on a dime! I also have 18" wheels in front and 20" in back with matched tires so that contributes to the rake on mine. My dad's '66 Burb in the background is stock. I'm about 3.5 inches lower at the front bumper than him, still the same ground clearance as my stock Subaru though!
#24 | |
Re: My '66 Suburban
#25 |
Re: My '66 Suburban
A 3/5 should be pretty easy with rear springs and drop spindles in the front. The spindles will help keep a better ride quality and through proper suspension geometry whereas springs can easily throw that off.
