08-25-2014, 09:23 PM | #1 |
Part Out/Sell Whole, 67 c10 2wd long rough shape
I picked up a 67 c10 2wd with a very rough body. Grabbed a few parts for my dads truck, not much I could use on mine. It has to be gone by Oct 1st. I work during the day, so picture taking and parts pulling will be in the evening.
1. Since the body is so bad other than the cab, I'm going to offer patches of fenders. It is a steel floor bed, but is quite bad. Not sure I can get a good patch, will have to look closer. 2. :edit: cab is sold. 3. I need to keep this a rolling chassis as long as possible. If you need suspension parts, I can do that at the very end. I also have a pile of other parts from past situations, they are forsale as well. Parts are located in 72120, and would like to try and ship "if it fits it ships" as much as possible. Still here and good.... engine last ran in 2002, said it ran good 3speed trans, said they had it rebuilt at some point air cleaner (in accessory pic) seat frame is here Parts I know are bad/gone..... headlight bezels park lights backup lenses cluster grill shell 1 grill ring front bumper door handles/cranks door panels(1missing, 1 damaged) all body panels have some sort of damage. cab rear springs carb gm goodwrench VC's in misc parts picture gone.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) Last edited by Dale99; 09-07-2014 at 07:48 PM. |
08-25-2014, 09:35 PM | #2 |
Re: Part Out/Sell Whole, 67 c10 2wd long rough shape
How much for the one lonely hubcap shipped to Ga 30114 ?
08-25-2014, 09:38 PM | #3 |
It has some dents, could likely be hammered out. If it will fit in the medium box, I would do 20 to your door.
08-25-2014, 09:39 PM | #4 |
interested in the window crank handles if those are still there as well as the dash knobs if they are the deluxe. and how is that passenger fender?
1967custom |
08-25-2014, 09:45 PM | #5 |
window/crank handles were broken or used on my dads truck.
not sure which knobs are deluxe, can you post a pic of what your looking for? (edit these knobs are solid black, I don't think that's deluxe?? pass fender has typical rust front and rear, plus dents along front edge |
08-25-2014, 09:50 PM | #6 |
Junior Member
Is that a sport mirror backing plate mixed in with the other parts? If so, I'm interested in a price shipped to 89044.
08-25-2014, 09:50 PM | #7 |
Surface rust or eaten thru and pitted?
Also the deluxe knobs will have the srainless center and ridges along the edge like a quarter. I know i need more. Ill have to go look at my truck
1967custom |
08-25-2014, 09:54 PM | #8 |
muckmuck, yes you are correct. It is heavily rust/pitted but still quite solid. I would do 8 to your door in small usps box.
Michael, full eaten thru front and rear lower. That is not the knobs I have, sorry. |
08-25-2014, 09:58 PM | #9 |
muckmuck.. Is this also the correct side you need?
08-25-2014, 10:00 PM | #10 |
Junior Member
08-25-2014, 10:03 PM | #11 |
08-25-2014, 10:48 PM | #12 |
Price for carburetor and complete fuel line from carb to fuel pump shipped to 73644 please. Thanks, Dustin
08-25-2014, 11:12 PM | #13 |
how much for the electric fan ?
Bret Here's a link to my build http://67-72chevytrucks.com/vboard/s...d.php?t=577889 |
08-25-2014, 10:02 PM | #14 |
Michael....
08-25-2014, 11:53 PM | #15 |
Need a 6 cyl upper alternator bracket. If u have one how much shipped to 08753?
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
08-26-2014, 12:35 AM | #16 |
Dang i was hoping the cup would be good on the fender. Thank you though.
1967custom |
08-26-2014, 02:16 AM | #17 |
one set closer
How much for the ignition bezel?
08-26-2014, 08:24 PM | #18 |
I tried pulling it tonight, its in good shape. I have the removal tool, but it still wont come off. After fiddling I searched and I guess I need the keys to this, which I don't have. If you know how to get it out w/o the keys, let me know.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
08-26-2014, 07:05 AM | #19 |
maddoxdb. The hard fuel line stops slightly before the pump and turns into rubber. Is that correct?
bertvert. I was thinking 20plus ride. It is 12" summit brand, flows 1100cfm. scott, should still be there. Will verify tonight. Michael, thanks for looking. upgrade, a few dollars plus ride. Will get better pics tonight for you. |
08-26-2014, 08:48 AM | #20 | |
08-26-2014, 12:46 PM | #21 |
What is your price on the cab with the doors. Doors dont need to be complete but I would like the outer door handles.
Thanks. |
08-26-2014, 02:01 PM | #22 |
one set closer
Ok thanks.
08-26-2014, 02:38 PM | #23 |
Looks like a 292. I am interested in the head. Any idea when the last time this thing ran? Please provide a price with shipping to 60109.
Thanks for your time. |
08-26-2014, 09:24 PM | #24 |
I hunted around and finally found a weight of 73lbs on autozone website. Plugged it into UPS at 80lbs and got a $70 alone for shipping.
08-26-2014, 06:28 PM | #25 |
Waylon bud... cab, cab windows, doors, door windows, outer handles, crank assy, steering column, glove box, title, BOS. I will do 150 you come get it. 250 will get the the whole truck minus rims and gas tank.
59bones. I'm not sure how to tell engine size on I6. Where is it and I will verify engine size before I pull the head. Last ran 2002. About to pull parts/take pics of all other stuff. |
