08-28-2014, 06:16 AM | #1 |
Sealant on thermostat gasket?
Got a couple questions about doing the thermostat gasket on 87 5.7L.
1. Do you use sealant? Like that RTV stuff. I've heard some people don't, and some people do. I just tried sealant and it leaks! 2. Does the thermostat sit on top of the gasket, or go underneath it? Strange question, but looking at it I realize that the thermostat is a lot bigger around than the hole in the gasket. |
08-28-2014, 06:25 AM | #2 |
Re: Sealant on thermostat gasket?
No sealant. I use the good Felpro gaskets on top of the thermostat.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
08-28-2014, 08:38 AM | #3 |
FelPro: 35562T
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-28-2014, 07:22 PM | #4 |
Moderator
The FelPro: 35562T raised ring gasket and some Sil-Glyde with the original water neck is one of the best things since sliced bread. Usually they're re-usable too.
Back in high school... I mounted a smallblock water neck in a 4 jaw chuck on the lathe at school and cut an o-ring groove. That worked pretty nicely to stopper up the leaks. A couple buddies did the same. I suppose I could've mounted the water neck or an intake manifold on a rotary table and cut the groove with the J-Head Bridgeport but the lathe was more accessible.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
08-28-2014, 07:29 PM | #5 |
Thanks for all the help everyone.
I did buy a felpro gasket but its not the one with the ring. Its just a plain blue one. I take it from the replies, that the waterneck leak on the 350 is a very common problem on that engine? |
08-28-2014, 09:52 AM | #6 | |
Thermostat, gasket, housing. Yes I use RTV.
08-28-2014, 11:04 AM | #7 |
Ive always used rtv, never game me any problems
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
08-28-2014, 11:09 AM | #8 |
I must be old school from the prehistoric age, I smear a film of grease on the gasket.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
08-28-2014, 12:06 PM | #9 |
The FelPro gasket I posted needs nothing. It is the cat's meow, and it is re-useable! Pricey though, but I am very, very impressed with it.
08-28-2014, 12:08 PM | #10 |
X2! Best thing since canned Coors.
08-28-2014, 12:16 PM | #11 | |
Technically gaskets don't need sealer, the gasket is the seal, but a little extra insurance doesn't hurt.
08-28-2014, 12:51 PM | #12 |
I've always put a thin film of rtv on both sides of the gasket.
08-28-2014, 06:49 PM | #13 |
I'll use whatever's handy. Grease, I'll use on a lot of gaskets. RTV, if the tube is a lot closer than the grease.
The key seems to be, make sure the mating surfaces are clean. Skunksmash, iirc, there is a recess on the intake manifold side where the thermostat sits, gasket over it.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
08-28-2014, 07:45 PM | #14 |
The gasket, housing surfac and thermostat are the same on both small and big blocks. Leaks are common due to dirty or pitted surfaces, thermostat over gasket, fancy o-ring water necks and gasket sins...crap gasket, RTV glopping, etc. A good gasket and clean surfaces are all you need.
08-28-2014, 08:08 PM | #15 |
X2 on the reusable Fel-Pro gasket! For the money and effort, I usually go with a new housing along with it.
08-28-2014, 09:14 PM | #16 |
I use right stuff and gasket , but recently I had no gasket so I beaded the right stuff thick then wait for it to semi cure then place then place the cover on top
08-29-2014, 08:59 PM | #17 |
Will any 350 waterneck work? A friend of mine bought one about a year ago and it was a cast piece of junk. When he tightened down the bolts it cracked. I'd like one that's not cast metal if possible
08-29-2014, 09:26 PM | #18 |
The chrome ones are usually junk castings. There is a cast aluminum one you can get for under $10 that I've had good luck with. I usually get them from Rock Auto. I just got a couple so I can find the part number if you need it.
Jeff
08-29-2014, 09:31 PM | #19 |
Just found my Rock Auto receipt from last week. It was a Four Seasons #84823 at a cost of $5.95. It has the tab for the return spring as well. Good luck!
Jeff
08-30-2014, 04:17 AM | #20 |
Return spring? What return spring? lol
But seriously I didn't see any spring |
