![]() Join Date: May 2013
nv4500 swap with bench seat
Has anyone done the nv4500 swap with a bench seat? I have a lead on a nv4500 but I want to keep my bench seat. I hear that it makes the 4x4 lever interferes with the seat. Can anyone shed some light on this?
Re: nv4500 swap with bench seat
I did one years ago in the truck in my avatar pic. probably not the same set up you will use, but it worked fine for seat and shifter clearance.
http://67-72chevytrucks.com/vboard/s...75&postcount=2 that post shows the shifters. not sure the tcase shifter is actually hooked to the linkage, but it cleared fine. |
![]() Join Date: Feb 2007
My combo has the transfer case mounted directly to the 4500's tail shaft. The 205 shifter just kisses the bench when shifted into 4wheel. Currently I am moving the drivetrain forward 2 inches so that will be alleviated as well as other clearance issues.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Thanks for the info guys. For some reason I was thinking that the shifters would be very close to the seat. Looks like its not that big of an issue.
I think it depends if you move the transfer case back or move the engine forward. The NV4500 is longer than your OE trans.
