Helpneeded with manuel Shifter 1966 c 10
hello
Hope you can help me ..Ive a 1966 c 10 with manuel Transmission . the shifter sits on the steering colum . When I drive sometimes I can manage the gears only the first vgear will goo or only the second .or only rear .. I think the part that sits on the steering colum in front of the Firewall didnt work so god. I dont know what the Name of the part Maybe someone can help me or have one of those parts... Many thanks !!! |
![]() Join Date: Jul 2007
Re: Helpneeded with manuel Shifter 1966 c 10
I would recommend decreasing the column and getting all the black gunk off. Then you should be able to see better. Make sure the 2 arms are parallel when it is in neutral. There is a hole in the middle part that will allow a drill bit or nail to go through all 3 parts. If it will not un clip the linkage and adjust it until it does. Once you get it lined up you cam lube it with white spray grease. My 3 speed shifts with 1 finger.
Hey Jurassic-1
Thanks !! I ll try that would be glad when I also can shift with one finger !! Mike |
![]() Join Date: May 2010
Mike c 10 you have a Beautiful truck! How much drop does it have?
It only has original paint once |
Hello Mathew 21
thanks!! I got this c 10 a few weeks ago and it came like it is ... I has 15 Inch steeles ..Iin the rear I has LJ Wrangler lowering springs with shorty Shocks...front could be cut the coils maybe one ring.... I haven´t take measure..but I agree with you..it Looks good.. Mike |
