Old 08-31-2014, 12:24 AM   #1
eric8
Installing clutch pedal
I'm trying to put a clutch pedal on my 72 c10. I know the pedal shaft just slides onto the left end of the original pedal box assembly (in theory) but I'm finding I don't have room to move the pedal far enough to the left to get the pedal shaft in the hole! What am I doing wrong? Did you guys have to pull the whole pedal box to get the clearance needed to get the pedal mounted? Thanks!
eric8 is offline   Reply With Quote
Old 08-31-2014, 02:52 AM   #2
Ugly71C20
Re: Installing clutch pedal
I gave the sheetmetal a little tap with a 2# hammer to get the clearance needed. Its under the cowl so you can see it.
Ugly71C20 is offline   Reply With Quote
Old 08-31-2014, 08:28 AM   #3
eric8
Ok cool, just wanted to be sure I wasn't missing something obvious before I started "ramming it home. ". So it is indeed a very tight fit. Thanks.
Old 08-31-2014, 09:04 AM   #4
R.L.
R.L.'s Avatar
Yeah I had to tap the sheet medal too, make sure you grease the shaft and install new neoprene washers or that thing will squeak every time you step on the clutch.
R.L. is offline   Reply With Quote
