Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-31-2014, 10:55 AM   #1
coolguycentral
coolguycentral's Avatar
Headlights on, wont go out!
I took my super 72 out for a joyride a couple weeks ago, she ran great. I pulled up to the garage and noticed the headlights were on. I checked the switch, it was off and no other lights were on. I checked the high beams they still worked. Turned the light switch on, all the dash, parking lights etc. came on no problem, but when I turned off he switch the headlights still remained on. I pulled her into the garage and shut her off and the headlights were still on, with the switch off and ignition off. I disconnected the battery for the evening. I pulled the dash, replaced all the bulbs in the dash, replaced the headlight switch, checked all the other bulbs in the truck, and when I reconnected the battery: headlights on! I looked at the wiring to the sockets and the grounds and have nothing.
Any similar issues, possible solutions, or suggestions that I haven't covered yet?
coolguycentral is offline   Reply With Quote
Old 08-31-2014, 01:46 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Headlights on, wont go out!
In your headlight plug there is a red wire that feeds the switch with with power. The blue wire that is there also, is the feed wire for the headlights, and it runs to the dimmer switch on the floor board. The blue wire is not hot until the headlight switch is pulled out all the way. If you have a short in the plug between the red wire and the blue wire, then you would have headlights all the time. Did your headlights stay on when the switch plug was pulled off the headlight switch?
Here is a picture of the switch and how the wires go.
Name:  Headlight Switch 1.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-01-2014, 01:32 PM   #3
coolguycentral
I just pulled the harness out of the new switch, connected the battery and still the headlights are on. The harness is in great shape. Im going to mess with it tonight.
Old 09-04-2014, 08:27 PM   #4
coolguycentral
I pulled out the dimmer switch and noticed some corrosion on the connections. I am going to replace the dimmer switch and harness and see where this gets me.
Sleeper '72 Cheyenne Super
Old 12-13-2021, 12:51 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Old thread... but did this ever get resolved? I ran into the exact same problem last night on my 62...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-13-2021, 06:51 PM   #6
El Dorado Jim
following
El Dorado Jim is offline   Reply With Quote
Old 12-15-2021, 04:56 PM   #7
jchav62
1962 C-10
jchav62's Avatar
For me it was the dimmer switch connector. I plan on replacing the switch and the connector soon, but I was able to temporarily fix it with insulated connectors...
JC62
Joseph Chavez
Old 12-15-2021, 06:40 PM   #8
bhap
bhap's Avatar
If you have headlight relays, give them a sharp "tap" and see if the lights go out.
bhap is offline   Reply With Quote
Old 12-15-2021, 08:44 PM   #9
RustyPile
RustyPile's Avatar
Or disconnect the main power feed to them.
RustyPile is offline   Reply With Quote
Old 12-16-2021, 01:57 PM   #10
kwmech
Faulty headlamp switch--power has to come from the switch before it gets to the dimmer, unless relayed as stated above
Old 12-15-2021, 08:41 PM   #11
RustyPile
RustyPile's Avatar
JC62
This doesn't make sense. The headlight switch provides power to the dimmer switch. If the headlight switch is working properly, when it's off, there is no power applied to the dimmer switch. Therefore, the lights cannot remain on (and not turn off) if the dimmer switch fails.
electrical, headlights, switch
