Old 08-31-2014, 08:38 PM   #1
kha4079
throttle pedal and cable for 65 c10?
anyone know which one to get i eliminated the old linkage crap and now i need the pedal with cable and hardware for my 5.3 swap. anyone know where to get one? i been looking throughout this whole forum and all i see is for 68 and up... thanks in advance
kha4079 is offline   Reply With Quote
Old 09-01-2014, 12:46 AM   #2
66 C10 383
Re: throttle pedal and cable for 65 c10?
Starting at port 110 Mark shows how he adapted a cable throttle pedal from a 71 - 72 C10.
http://67-72chevytrucks.com/vboard/s...le#post5286113
Post 41 shows a Lokar pedal ...
http://67-72chevytrucks.com/vboard/s...le#post6284534
Post 668 shows another one.
http://67-72chevytrucks.com/vboard/s...le#post6611436
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 09-01-2014, 04:36 AM   #3
Dismas
I went to pick n pull and yanked the pedal assembly and cable from a late 70-early 80's ish chevy.
I used the post referenced above to aid on the changeover, though on my 66 things lined up a smidge different.
If you go the junkyard route, make sure to also nab the bracket that holds the carb side of the cable, the one I have bolted to the intake manifild, looks like it also has a spot for a kickdown levercable/whatever to mount, but mine is a manual tranny.
I did the gas pedal changeover plus reinstalled my MIP floor mat correctly ( PO had done a horriblr job, totally misaligned) and installed retracting seat belts for deiver and passenger, then mounted 2 old belts in middle so kids could have belts, and it took a total of about 7 hours for all 3 projects.
Dismas is offline   Reply With Quote
