Old 08-31-2014, 11:39 PM   #1
Roll'nSlo
Roll'nSlo's Avatar
Smog removal
I'm working on someone's truck. They want to remove the air pump and other smog equipment. My question is, how will it run and how driveable would it be? It's an '87 C20 with a 454.
Roll'nSlo is offline   Reply With Quote
Old 09-01-2014, 12:10 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Smog removal
It will work just fine and have a bit more power than stock. Make sure you either re-route or plug off all vacuum lines that need to be eliminated when you're done, and it will work just fine. You may need to tune the carb differently and slightly adjust the timing, but other than that, it's pretty straightforward.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-01-2014, 12:42 AM   #3
Roll'nSlo
Roll'nSlo's Avatar
Re: Smog removal
It has a TBI system on it. Will it still work just fine??
Old 09-01-2014, 09:19 AM   #4
Chevy3+3
Re: Smog removal
I pulled off the smog system when I put headers on my 87 TBI 350. I just plugged everything off and took off the pump and belt. I didn't adjust anything else. Everything seemed to run fine.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 09-01-2014, 09:53 AM   #5
dfrank
dfrank's Avatar
Re: Smog removal
If it has tbi then you wont have to mess with the carb at all. It should run fine.
dfrank is offline   Reply With Quote
Old 09-01-2014, 11:48 AM   #6
Roll'nSlo
Roll'nSlo's Avatar
Re: Smog removal
Cool!!!! Thanks everyone. I've pulled it off before but at the same time I've switched it to carb system. I wasn't for sure if it would mess with the TBI
