09-06-2014, 11:50 PM | #1 |
Removing a dash cluster
Is there a secret to removing the speedometer cluster from the dash of my 61 C-20?
I've taken the screws out of the bezel, but it won't budge. Anything behind the dash? Thanks in advance |
09-07-2014, 12:54 AM | #2 |
Re: Removing a dash cluster
If you have removed the screws you should be able to push it out from behind.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
09-07-2014, 08:25 AM | #3 |
Do you have the speedometer cable removed from the speedometer? Also may have an oil pressure line connected behind the gauge.
09-07-2014, 08:38 AM | #4 |
I'll try that. Mine just has the idiot light
09-07-2014, 09:09 AM | #5 |
Sometimes a little push from the back side helps. Some fall right out...some are a little tight.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
