09-11-2014, 10:42 PM | #1 |
67-72 4x4
I am wanting to do a 2X4 to 4X4 frame swap and want to know which frames will fit best. i know my wheelbase is 115 and 4x4 frame after 72 are 117 wheel base. Can anyone help me with the frame they have used and what problems if any the have incurred. thanks Bill
09-12-2014, 12:34 AM | #2 |
Re: 67-72 4x4
The easiest way is to sell your truck and buy a 4x4 one.The hard way is a 4x4 swap which can be done on your stock 2wd frame but its a lot of work and time to do it.Look at http://67-72chevytrucks.com/vboard/s...d.php?t=310493
09-15-2014, 10:12 PM | #3 |
Re: 67-72 4x4
I appreciate your thoughts on the SAS swap, but it will be a daily driver and unless the Geometery is correct bump still with rattle your teeth. So I would prefer to have 4x4 instead of SAS. Thanks Bill
09-16-2014, 02:31 AM | #4 |
Re: 67-72 4x4
Are you trying to use a ifs 4x4 frame?
09-16-2014, 07:43 PM | #5 |
Re: 67-72 4x4
NO I am trying to find out which frame I could mount my 69 shorty to, with the least amount of changes. I know 1973-78 short bed 4x4 frames are the closest in wheel base length being 117 inches. and the 67-72 shorty frames are 115 inches. Was trying to found out if the width is the same. Also if someone has done it what problems the have come across.
10-03-2014, 12:20 AM | #6 |
Re: 67-72 4x4
I used a 77 frame and took out 1.5 inches (behind the cab). I have never had any problems with bump steer.
10-04-2014, 11:29 AM | #7 |
Re: 67-72 4x4
I think the easy way to do this will be to find a long 67-72 k10/20 and cut it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
