Old 09-12-2014, 05:56 PM   #1
jtinpdx
How to tell if I have an HEI distributor?
Hi All,
First post here, but have been gathering great information from the forum. Love it.
I recently bought a 71 C10 long-bed. I've been doing some projects on it. In researching on this forum about how to get my Temp gauge working, I've come across discussions about HEI distributors.
Dumb question - how do I know if I've got one. It's a 350 with an Edelbrock carb. But what else should I look for determine?
Thanks,
Jeff
jtinpdx is offline   Reply With Quote
Old 09-12-2014, 06:44 PM   #2
franken
Re: How to tell if I have an HEI distributor?
Google HEI, look at pics, then look at yours. HEI looks much bigger since the coil is in there, making the cap way bigger.
Or look for an external coil and a coil wire going to the top center of the cap.
Old 09-12-2014, 07:19 PM   #3
JimKshortstep4x4
Welcome to the 67-72 Chevy Truck Board from West Michigan!
Attached is a picture of an HEI installed in a BBC. The distributors are the same as the SBC distributors.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-12-2014, 07:57 PM   #4
davepl
davepl's Avatar
Since we're talking about HEI, remember that a lot of us have robbed them out of mid-70s and 80s cars because even though they weren't great at high RPM, they were self-contained and pretty much bulletproof otherwise.
I like to point out, however, that the advance curve and the vacuum advance pot are, by definition, set up for a 70s or 80s smogmobile. How different that is in terms of total advance and when it comes in I'm not really sure, but it's probably worth checking if you're concerned about having that kind of thing correct.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-12-2014, 09:04 PM   #5
notchbackgta
HEI comes in small cap with an external coil too
notchbackgta is offline   Reply With Quote
Old 09-12-2014, 09:42 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yep... those came on TBI equipped vehicles. But I'm sure he's probably talking about large cap with the internal "coil in cap".
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-12-2014, 09:59 PM   #7
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Post a picture of your engine and we can let you know what you have!
Welcome to the board from Texas
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 09-14-2014, 09:32 AM   #8
Take the cap off and see if you have points and condensor in there.
Old 09-14-2014, 10:59 PM   #9
jtinpdx
Thanks for the help, guys. I'll take a closer look and post a picture. Appreciate the responses.
Old 09-19-2014, 01:26 PM   #10
jtinpdx
Here's what I'm looking at guys. What do you think is in there?
Old 09-19-2014, 01:29 PM   #11
70shortfleet
70shortfleet's Avatar
That is a stock set up, not HEI
70shortfleet is offline   Reply With Quote
Old 09-19-2014, 01:31 PM   #12
jtinpdx
Does that mean points in 71 350?
Old 09-19-2014, 01:59 PM   #13
bigmac73
bigmac73's Avatar
oh yes, and do not tie into the existing wires , just run a heavy gage red wire from a Ingnition source from the fuse box to the distributor when you install it ,
make sure the fuse source only has power when the ignition is on
Easy install,
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-19-2014, 02:02 PM   #14
bigmac73
bigmac73's Avatar
http://www.summitracing.com/search/y...57&keyword=hei
Mike
Old 09-19-2014, 02:17 PM   #15
jtinpdx
Thanks guys. BigMac, lots of choices on Summit Racing. Have a favorite? I'm not looking to build a race engine, but a few more HP and smooth running would be great.
Old 09-19-2014, 02:24 PM   #16
jtinpdx
http://www.summitracing.com/parts/msd-8360/reviews/
This one looks simple and solid. Any compatibility issues with the stock 350?
Old 09-19-2014, 07:28 PM   #17
bigmac73
bigmac73's Avatar
do not waste your money on that one with a stock motor, no sense in spending that much money, If you do not go with the petronix version, I use a MSD Street fire have not had any problem
Mike
Old 09-19-2014, 02:27 PM   #18
jocko
jocko's Avatar
You can also maintain your stock look with a stock cap by installing Pertronox in place of your points. Lots of info regarding Pertronix conversion on this site, explore before you buy HEI and decide that it's huge and hideous! Some think that. I'm on the fence - I prefer the stock look, but HEI is clearly a FAR superior system to points. That's why I usually go with Pertronix. Stock look, no points. Cool setup in my book.
http://www.summitracing.com/parts/pnx-1281/overview/
http://www.summitracing.com/parts/pnx-40011/overview/
Note these are the Flamethrower I systems - there is also a Flamethrower II that includes additional features. Good luck on your conversion!
Old 09-19-2014, 02:48 PM   #19
jtinpdx
I'm liking what I'm reading about the Pertronix conversion, Jocko. Might go that route. Seems simple and everybody has great feedback on it.
Do you notice a decent power increase?
Old 09-19-2014, 07:42 PM   #20
jocko
jocko's Avatar
you won't notice a major change in performance with pertronix, but you will notice it doesn't degrade as new points wear to become old points, because there aren't any. You'll see a very minor increase in power, if combined with good quality plug wires, a pertronix hi-volt coil, along with the pertronix point replacement unit. It's nothing to write home about, but it is a great upgrade for maintainability. If you want to maintain any sort of stock look, I think it's the best/least expensive way to go. You need to pull the dizzy to install - I had a Pertronix I and had to shim the distro shaft. It's not always required, but it's required to check end play, otherwise timing will be erratic. (this problem is present with points also... it's just a smart thing to do). The shim(s) minimize end play in the distro shaft.
Old 09-19-2014, 09:40 PM   #21
davepl
davepl's Avatar
Stick a Pertronix in a factory or repro small body housing. Even with a stock coil it'll be plenty for non-supercharged applications, particularly if you're under 11:1 compression, which I presume you must be.
I have the Ignitor III in my 402 and the Ignitor II in my 502, both are great. The III causes problems with some repro tachs, but I borrowed and then bought a unit that appears to work with the III as well (random luck,I think).
Old 09-20-2014, 05:17 AM   #22
jjzepplin
jjzepplin's Avatar
I wouldn't underestimate him. He DOES own a 67-72 Chevy (71). This is just like learning anything else. Gotta start somewhere. When I put my first hei in my Chevelle I went for the Accel dizzy and full curve kit. Man what a difference. All I did was read instructions. I know-not really a manly thing to do but they were right there and in words that I understood and all so why not read them.
If it's running ok now then just do some reading up on the subject. Meanwhile drive your new truck til it starts acting up.
You will need new wires too so save this upgrade for the next tune up and you will be amazed.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-22-2018, 11:55 PM   #23
Christian Car
New to forums. I hope I'm doing this right. Im pretty sure I have an hei distributor. If I do, what gap should I put on my plugs? I've read that it ranges from .045 - .06 for an hei. Does that vary based on which hei distributor I have?
Christian Car is offline   Reply With Quote
Old 10-23-2018, 10:30 AM   #24
68 P.O.S.
The gap should be .045 for HEI. When HEI first came out the gap was .060, but was burning the tips of plugs, so GM changed it to .045
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
hei, hei conversion
