Old 09-14-2014, 10:56 AM   #1
72chevyrick
solid motor mounts
I'm putting a BBC in my 66 short bed andwant to use solid mounts.I know i can get the mpunts for the engine,but cant find the brackets for the frame...
72chevyrick is offline   Reply With Quote
Old 09-14-2014, 11:07 AM   #2
72chevyrick
solid motor mounts
I'm putting a BBC in my 66 short bed.It will be raced and want to use solid motor mount >i can find the mounts for the block but not for the frame.any ideas ?
Old 09-14-2014, 11:18 AM   #3
PGSigns
PGSigns's Avatar
Re: solid motor mounts
Unless this is a drag race only setup i would not do it. The frames on these trucks have to much flex and something will break. When I put the 396 in the 64 I had we had to make the frame mounts. Since these trucks never came with a big block there are no factory stands.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-14-2014, 11:57 AM   #4
72chevyrick
Thanks jimmy.i know i have my work cut out.i have a couple friends who run S/G and who are excellent fabricators.the engine came out of a dragster and is putting out right around 900.yes it will see 99% strip but will be taged for the street to.
Old 09-14-2014, 11:59 AM   #5
72chevyrick
I like you marv,no sugar coating..lol..i hope i wont hear the i told you so..
Old 09-15-2014, 12:54 AM   #6
Captainfab
60-66 Nut
I have some solid motor mounts of the '73+ style that I made. You would just need the frame brackets from a '73-'86 C20/30 or a '87-'91 R2500/3500.
Old 09-14-2014, 11:56 AM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
hahaha Rick,, email replied, But pretty much exactly what PG said. Your truck YOUR choice,,, just be aware.... and ready for the "I told you so"
LOL
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-15-2014, 04:47 AM   #8
Gumby
Gumby's Avatar
with that much power he can afford to stiffen up the frame........ Could even put a plate on each side and make the bed n box one unit.
Gumby is offline   Reply With Quote
Old 09-15-2014, 06:43 AM   #9
PGSigns
PGSigns's Avatar
With that much power it will need a full cage to get down the track. If track only a motor plate and a mid plate would be much better and get the load off the trans. Then if you run a trans mount with the plates use a soft stock mount. Use a plate where the stock mount went to put your engine limiters.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-19-2014, 01:25 PM   #10
72chevyrick
thanks for all the input.will keep you updated as i go
