Old 09-14-2014, 11:10 AM   #1
randy.powell
Question Door Hinge Bolts/Anchor Nuts
Trying to adjust my d/s door on my 71 Cheyenne Super and discovered that 2 out of the upper 3 door bolt anchor nuts are stripped in the door. Anyone have advise on how to repair/replace?
Any wisdom would be greatly appreciated!
Thanks!
Randy
randy.powell is offline   Reply With Quote
Old 09-14-2014, 11:46 AM   #2
Wizo
Wizo's Avatar
Re: Door Hinge Bolts/Anchor Nuts
randy.powell; I had this happen on the truck I'm working on. only mine was so bad that I had to completely cut the hinge out from the door and replace it with one that I scrounged from a wrecking yard by welding it back in with a mig welder. what a PTA that was because I had to weld the hinge in and then when I was done I had to weld the cut out piece of door skin back in place. Fortunately my truck was in the restoration stage still. I don't know if yours is in the drivable stage or not but one of the things you could do is take the door panel off Put the bolts back in And a line it properly, open the door all the way and support it with a floor jack And then reach inside the door panel with Individual nuts for each bolt and screw them on tight. good luck and let us know how that works.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 09-14-2014, 11:54 AM   #3
kxmotox247
kxmotox247's Avatar
I used a heli-coil to fix one of mine. I just drilled out the captive nut with the special drill bit...tapped it for the new heli-coil and installed the heli-coil.
kxmotox247 is offline   Reply With Quote
Old 09-14-2014, 02:43 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Why not just take the door off and drill and tap to the next size bigger bolt? That is if you are talking about the door? I have been cutting up doors for my crew cab project and the inside nuts you speak of are actually an L bracket shaped pieces with threads similar to a nut. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-14-2014, 02:48 PM   #5
71blksuper4x4
SWB 4x4 Collector
This is the top bracket out of a drivers door.. I was wrong....there is nuts on the L bracket. Trevor
TREVOR
Old 09-15-2014, 08:53 AM   #6
randy.powell
So are the captive (cage) nuts replaceable? It feels like they "float" in the door. Or are they a part of the "L" bracket and the whole assembly has to be replaced? I'm trying to avoid having to remore/cut the door as she is a driver. Paint is good so I don't want to come in via the outside door skin.
Not enough room to drill and tap for helicoils with the door attached. I'm a "one man" army with a bad back so it's too much for me to try and manage door removal by myself. Sucks getting old!
I appreciate all the input, ideas, and pics! You guys (gals) on this board are the BEST!
Best Regards,
Randy
