Old 09-15-2014, 02:32 PM   #1
Sodak
Active Member
81 to 73
Just bought a 1981 4x4 short box stepside with 4 headlights and want to convert it to the two round style of the 73-79 style. I know all the sheet metal has to change including the hood,rad supprt and bumper. But what else? wiring ? body shims? any help appriciated.
Sodak is offline   Reply With Quote
Old 09-15-2014, 06:23 PM   #2
walkerb
walkerb's Avatar
Re: 81 to 73
I would include headlight wiring, bumper, radiator shroud. And figuring out the wipers. If I remember correctly the 80's wiper mounts are too tall? And body mounts are different somehow
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-15-2014, 07:37 PM   #3
Sodak
Active Member
Re: 81 to 73
Body mounts too tall?.. does that mean i have to shim the radiator supprort?
And thank you for this info ,as it does help,Need my ducks in a row before i try this .
Old 09-16-2014, 06:31 AM   #4
walkerb
walkerb's Avatar
Re: 81 to 73
Again if I'm remembering correctly the 80's are taller then the 70's.
Old 09-16-2014, 12:08 PM   #5
Sodak
Active Member
Re: 81 to 73
Thank you i'll check that out,and if so? change the mounts to 70's spec?
Old 09-16-2014, 11:35 PM   #6
Your41Plague12
Your41Plague12's Avatar
Re: 81 to 73
The wiper posts are taller, not the body mounts. You'll need to change the wiper posts (the splined part that rotates, the wiper arm presses onto it) to the 73-80 style. Other than that, it's a pretty straightforward swap. The ends of the frame rails at the front bumper are different on a 73-80 truck too. They're not cut at an angle like the 81-87's are, so the factory 73-80 bumper won't bolt up without some fab work. Not sure if the 81-87 bumper will fit with the 73-80 fenders and core support, but even if it did, it wouldn't be correct.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-17-2014, 11:02 AM   #7
Sodak
Active Member
Re: 81 to 73
Thank you.. now i'm sure i'mn going to try this.
