Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-17-2014, 05:06 AM   #1
adammoore
Swapping manual to power seats
hey i was wondering if anyone could help me?
I have a 2007.5 new body style chevy 2500hd silverado LT truck it has manual seats in it but i got some heated power seats out of a 2008 chevy silverado LTZ to put in my truck. the passenger seat pluged right in and the driver seat wont. My truck has 4 wire for the driver seat and the new seats has 14 wires and i was wondering if anyone could tell me how to hook it up. i have looked all over the internet and youtube and i can't find anything on how to hook it up or a wiring diagram on it.
Thanks Adam
adammoore is offline   Reply With Quote
Old 09-17-2014, 05:25 AM   #2
adammoore
Re: Swapping manual to power seats
this is the pigtail off of the wiring harness out of the 2008 chevy LTZ.
Old 09-17-2014, 05:28 AM   #3
adammoore
This is the factory plug in the 2007.5 chevy LT. i cut the red and black wires and connected them to the red and black wires on the 2008 LTZ pigtail to see if i could get it to move in any direction. it wouldnt move at all.
Old 09-17-2014, 01:42 PM   #4
_Ogre
_Ogre's Avatar
4 wire plug has hot and ground and 2 small wires for the seatbelt buzzer
14 wire plug has the same 4 wires, the rest are for seat heat and memory functions
unfortunately the memory functions require a new body module to operate
hook the red/white to red/white and black to black to make the seat work
tie the seatbelt buzzer wires together at the plug
as for the heated seat... your on your own
shop air compressor timer
Old 09-17-2014, 05:55 PM   #5
adammoore
Thanks for your reply.
I hood the red/white to the red/white and the black to the black and it wouldn't do anything. Someone told me that I would have to hook up more than just them two wires. But he didn't know what color wires all had to be hot (+) or (-)
Old 09-18-2014, 06:32 PM   #6
vidman
vidman's Avatar
Does the drivers seat have memory in it. Most people have no luck getting the memory seat to work..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 09-18-2014, 07:52 PM   #7
adammoore
Yes but I'm not wanting to hook it up. All I'm wanting to do is to get it to move. I'm also trying to find a switch for the dash so the heat will work to but that will be later. I'm just wanting it to move up, down, back and froward
Old 09-18-2014, 08:01 PM   #8
_Ogre
_Ogre's Avatar
post a pic of the under seat wiring
there may be a relay box that you need to bypass
should just be 2 wires into the switch
Old 09-18-2014, 08:59 PM   #9
Gonepostal
Gonepostal's Avatar
Drivers side Lg red ,lite blue and orange to 12v power black to ground. Passenger side lg red to 12v power black to ground
US Army Bomb Squad 83-96
There is no problem that a suitable amount of explosives cannot solve
Gonepostal is offline   Reply With Quote
Old 09-18-2014, 09:46 PM   #10
adammoore
Ok I will try that. I can't get the pics of the seat to upload but I will keep trying until I get them to.
Old 09-18-2014, 10:05 PM   #11
adammoore
Pics of the seat
Old 09-18-2014, 10:09 PM   #12
adammoore
Pics of seat
Old 09-19-2014, 02:31 PM   #13
adammoore
Hey I went and got a car battery and brought the seat and the battery in the house and hooked the red, orange and lite blue wires together and hooked them up to the positive (+) and the black wire to the negative (-) on the battery and it did not work
Do you have any more suggestions? Thanks
Old 09-19-2014, 04:15 PM   #14
gmachinz
I was perusing a factory diagram for the seat circuit and the actual relay controls inside the module are wires labelled A through H. But, the relays inside appear to be of a solid state design requiring a 5V reference signal to actually move. I'll do a little more research into it for ya....
gmachinz is offline   Reply With Quote
Old 09-19-2014, 09:02 PM   #15
Gonepostal
Gonepostal's Avatar
Just went and checked my seat and sorry mistake it was red/dk blue and orange. Lt blue is for heater controls.
Old 09-21-2014, 02:11 PM   #16
_Ogre
_Ogre's Avatar
your going to have to do some work
regardless of how many wires and sensors you have for the memory, the seat still has 3 motors and a switch
all the other stuff is just stuff. stuff that needs to be cut out and thrown away
the easy way would be to look at the passenger seat and hook everything up similar to the pass seat
the switch should have 8 wires coming out; hot, ground and 6 wires, 3 pairs for each motor
each motor has 2 wires that need to be hooked to the switch
not sure if the drivers seat switch is rated for motor loads like the pass seat switch is
you could just set the pass seat in a good spot and transfer the wiring harness and switch over to the drivers side
Old 09-21-2014, 06:48 PM   #17
adammoore
Ok that's a good ideal! I will try that when I get back in town. Thanks for all y'all's help!!
Old 09-21-2014, 06:50 PM   #18
adammoore
I tried it with the bark blue wire to and it still didn't work
Old 09-21-2014, 07:03 PM   #19
Gonepostal
Gonepostal's Avatar
I put 01 Cadiliac 8 way power seats in my 68 and that's the ones I had to use and the plug on your seats looks very similar I will try and get some pics of the wiring
Old 09-22-2014, 03:02 AM   #20
adammoore
Ok thanks but hey it was worth a try! I don't have the seat in my truck yet I'm just using a car batterie. That should work right? I don't think the seat should have to be grounded anywhere since I'm hooking the black wire to the neg. (-). Do you know if that's right ?
Old 09-22-2014, 07:51 PM   #21
adammoore
Ok. Do you think I have a bad seat? I looked at the passenger seat and it only has two wires and they are red with a white line and black
Old 09-22-2014, 08:16 PM   #22
vidman
vidman's Avatar
My passenger seat had 6 or 8 wires and it worked fine, but the drivers had about 200 wires. I was told by 2 good chevy mechanics that the only way to get them to work was to rewire the whole assembly and bypass all the computer stuff. so it was a lot easier for me to bring them back and look for a non memory set
Old 09-23-2014, 10:04 PM   #23
Gonepostal
Gonepostal's Avatar
I just took the lrg red hook to 12v + and lrg black to 12v- then started adding wires to the + side till the seat moved then started removing other wires till it stopped moving and those are the ones you need for your seat. I used a jump box for testing. All functions work and they are memory seats that I have.
Old 09-24-2014, 12:45 PM   #24
_Ogre
_Ogre's Avatar
probably not a bad seat, it's just going to take some work to get it operational
if that is above your skill set then try to take it back
realistically you have 3 motors with 2 wires each
figure out how to hook up 2 wires to a motor to test it
Old 09-29-2014, 01:40 AM   #25
adammoore
I guess I had a bad seat! They let me bring it back and they had a lot more seats come in and we found one that would plug right into my truck and worked fine.
I would like to thank everyone for y'all's help!!!
Adam
electrical, power seats, seat, wiring diagrams
