09-17-2014, 05:14 PM | #1 |
4wd to 2wd hardline brake line kits???
hello all,ive recently been taking time off of my gbodies and am showing my 86 4wd k5 w/full top coversion/2wd conversion some loveive gotten all the front 2wd suspension done(bolted on,still have to make reinforcement frame bckets)and am currently looking into getting the brake lines(hardlines)routed/connected.can i use my existing master cylinder lines as well as the prop valve(4wd)and or make unions? or would i need to purchase(find in he yard) a new set of 2wd hardlines/prop valve? im also planning on using brackets made by member 'captfab" for a reardisc brake conversion that utilize 94-97 fbody calipers.any help/pics/know-how would be GREATLY appreciated!!!
09-17-2014, 09:17 PM | #2 |
I know the pieces fit
Re: 4wd to 2wd hardline brake line kits???
I don't know if the 2wd/4wd prop valves are different or not, you might be able to look them up for each somewhere like RockAuto and see if it's the same part number.
09-18-2014, 08:56 PM | #3 |
cool,will do
