09-19-2014, 04:36 PM | #1 |
Door Triggers/Switches
I am getting ready to install an alarm on my 66 GMC. I need to install door triggers. While I'm at it I'm going to wire the dome light into the triggers as well. I'm sure people have installed triggers/switches before. What is the easiest way to get it done? Photos would be great. It looks like it may be easier to put the switch in the door rather than the cab. Has anyone tried that? Let me know what you did. Thanks.
Rob 1966 GMC 1500 |
09-19-2014, 05:06 PM | #2 |
Re: Door Triggers/Switches
This is what I used...
napa has them in stock also http://www.oreillyauto.com/site/c/de...0946&ppt=C0335
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
09-19-2014, 05:47 PM | #3 |
09-19-2014, 10:02 PM | #4 |
I think you can do the button contact style at rear of doors. Haven't looked in awhile about through the vent.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
