Old 09-21-2014, 03:28 PM   #1
Sweet Willy
Sweet Willy's Avatar
Highway 15 wiring kit problem
Neither my turn signals nor my horn are working. They were but now they're not. I checked every fuse. I replaced the relay. Nothing. Dead as a door nail. Anyone have any clues where else or what else to check?
Sweet Willy is offline   Reply With Quote
Old 09-21-2014, 05:14 PM   #2
OrrieG
OrrieG's Avatar
Re: Highway 15 wiring kit problem
What kind of column, stock or later GM type replacement?
Old 09-21-2014, 10:48 PM   #3
Sweet Willy
Stock.
Old 09-22-2014, 09:18 AM   #4
47 Fasttoys
47 Fasttoys's Avatar
Start with one circuit at a time, horn is the easiest. The horn relay works off of a ground supplied by the horn button. You should have 12 volts on the relay anytime the ignition switch is on. When you press the horn button you should hear the relay pull in as the ground is applied from the horn button. Check that first and re-post.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 09-22-2014, 01:48 PM   #5
DransportGarage
DransportGarage's Avatar
American Auto Wire has pretty good tech support too. I'd give them a call if the problem persists.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 09-22-2014, 05:22 PM   #6
OrrieG
OrrieG's Avatar
Here is the stock turn signal wiring diagram (for a TF you did not say what yours is). It looks like the stock power comes from the accessory tab on the headlight switch to the flasher (stuffed up under the dash) then to the switch. If the new fuse box has the flasher built in to it there should be a wire from the flasher to the signal harness. I suspect that wire is missing or not connected right.
Old 09-23-2014, 04:48 AM   #7
tmoble
so what was the issue with it?
Is Highway 15 part of AAW?
tmoble is offline   Reply With Quote
Old 09-23-2014, 04:58 PM   #8
mr48chev
mr48chev's Avatar
I went to their website and while the kits may seem a tad spendy they have extremely detailed instructions online for each section or circuit.
I've read what Bob said about their good tech support on other forums over the years.
Keep us posted on what you figured out and how you fixed it.
My ongoing truck projects:
Old 09-23-2014, 11:21 PM   #9
Sweet Willy
Kind of embarrassing but both problems led to faulty grounds. It was that ole paint devil that got me. Filed off some paint. Hooked it all back up. And what do ya know. Like I've said in the past: "Some days it doesn't even pay to chew your way out of the restraints."
Happy Motoring!
