*Proud Member*
A/C Box to firewall... what to use to seal/mount ?
i'm looking to remount my A?C box on the firewall of my project... what should i use to seal it up??? the factory uses that terrible black stuff... can i use just clear silicon? any suggestions?
thanks! ![]() |
You get what you pay for
![]() Join Date: Dec 1999
I put mine back on with black silicone caulking. The black stuff the factory uses will work too though. One word though, the silicone is a biotch to get off if you need to. It's like glue.
Mike 1985 Chevy C-10 |
*Proud Member*
... how did the silcon you used agree w/ the paint on your firewall.... that's my primary concern...
Oh,you can't buy that new
![]() Join Date: Apr 2000
I got electricians sealing putty, comes as a block, gray or black in color. it rolled real easy into a 1/4" diameter rope and then layed it on there. it sticks pretty well. when you tighten the box it squeezes out and you can remove the excess very easy. availble at nearly any hardware type store. we call it monkey Sh*t at work and it is also called dum-dum. stays pliable. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. Last edited by crossy; 08-12-2003 at 12:22 AM. |
silcone will not take paint-- if your fire wall is going black use the black silcone --will blend in--the trick to remember is that you do not need to glob it on --if you look at the part that you are replaceing you will notice several flat spots and the rest will be edge runs. on flat areas you can be a little sloppy in making sure you get it covered-- on the edge runs -a thin line of silcone will work-- when you tighten the unit down there should be very small amount of silcone squeze out-clean extra off --should come out clean and no paint problems
tazman member of Mojave Street Rods |
The silicone won't hurt the paint, but you can't paint it. Paint won't stick to it. If you wipe off the excess when you get it on, it's fine.
I like Dave's idea too. I think anything that don't dry out on you would work. If it dries out and cracks, you may have some leaks down the road.
Gentleman Jim Driver
They sell some stuff at Home Depot called fingertip caulk. It sounds very similar to what Dave was talking about.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds |
sealers
keep in mind that silicone sealer...RTV...is ACIDIC until it dries (hence the vinegar smell). Have never seen it eat paint, but will react with bare metal. I'd run a bead on the a/c box and let it 'semi-cure' before putting it against the paint. As long as you dont 'flex' it, paint will stick.
just my 2 cents worth Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
Slots go on anything!
I used butyl tape, which is used to put windows in cars with. It is like a strip of sealant, similar to what was used at the factory.
1974 Jimmy- 5.3/4L80e/NP241 |
