![]() Join Date: Mar 2011
speedo cable
i converted a IL6 with 3ot to sbc and a 4speed m-20 and the (hook up is on oppisite side of trans)speedometer cable is short any suggestions is there a part # from a different year or model like a chevelle or el comino sure someone has had this issue
thanks jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Cluster King
![]() Join Date: Nov 2012
Re: speedo cable
If it was me, I would get a measurement of you existing cable plus the additional length you need and have a speedometer shop make you a new one. They should be able to set you up for around $30.00 - $50.00.
Other wise, you may find a application for a car that will work but you may have to play trial and error to get it right. Just my thoughts, Take care, tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
Re: speedo cable
than you i will see what i can find out let you know how i make out
#4 | |
![]() Join Date: May 2014
Re: speedo cable
Here is the one I bought. It says it doesn't work with 4WD. http://www.brotherstrucks.com/prodin...number=PLCBL01
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
#5 | |
Re: speedo cable
