Old 09-24-2014, 03:14 PM   #1
elane352
64 C10 saginaw power steering pump
Hello,
After replacing the power steering gear, I noticed that I needed to replace the saginaw pump.
Since the prior owner has passed, I do not know what pump part number I should use. I cannot get a part number off of the pump either.
Does anyone have an idea what type of pump I can use? I know that Cardone has parts 20-300 through 20-302. I was not sure about these since the web site refers to C4 and C5 series trucks.
Any insight would be appreciated.
Eddie
elane352 is offline   Reply With Quote
Old 09-24-2014, 11:48 PM   #2
Captainfab
60-66 Nut
Re: 64 C10 saginaw power steering pump
What engine is in your truck? Do you happen to have a pic you could post?
Old 09-25-2014, 08:55 AM   #3
mafosa
I rebuilt mine about a month ago. advanceauto part had the rebuild kit.
even came with the bushing. part # 7910 (powercraft) is the manufacture.
it has several different seals to cover different years.
this is the pump I have.
larry
mafosa is offline   Reply With Quote
Old 09-26-2014, 12:12 PM   #4
elane352
Many thanks for the photo. Just today I got the a Saginaw pump that looks exactly like yours. I had to return the other (non-Saginaw) pump.
I got so involved with the power steering gear replacement that I got lazy and asked my mechanic to deal with the pump since I could not get my hand down in the area to unbolt things. I darn near could not get a wrench down there well either. I just ran out of gas at that point.
Another thing that was a bit interesting and irritating was that I had to change the brake hoses. Now that part is not irritating in itself. But what was was the fact that the 3/16th brake line did not mate up with the 1/4 inch hose. What was on the truck were brake hoses with a 3/16th end for the 3/16th brake line. But if you order a brake hose for a 64 C10, you wind up getting a 1/4 inch hose. So my guess is that maybe the brake hose I replaced was for some other application that does have a 3/16 inch end. I did not determine which application it was.
I elected to put a small extension (1/4 inch male on one end; and 3/16 inch female piece on the other end).
Appreciate again your response and picture.
Eddie
Old 09-26-2014, 12:14 PM   #5
elane352
I have pictures unfortunately on my non-smart phone that does not have internet service. So I cannot even send them to you or myself.
I would have to use my digital camera to take some pics.
Eddie
