09-24-2014, 07:16 PM | #1 |
Painting the running boards recommendation
All, what do you recommend using to get the running boards painted to as close to original as possible?
Thx Pat
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
09-24-2014, 11:16 PM | #2 |
Re: Painting the running boards recommendation
I did not do my truck period correct but it is my daily driver. I just ordered a pair of these because painted running boards are very slippery when wet and scratches will show up eventually.
http://www.oldchevytrucks.com/cart/p...y%20treads|||| Here's my truck. http://67-72chevytrucks.com/vboard/a...1&d=1411272730 Last edited by Sweet Willy; 09-24-2014 at 11:22 PM. |
09-25-2014, 12:17 AM | #3 | |
Are the treads adhesive backed?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
09-25-2014, 04:50 PM | #4 |
Ive seen them rino coated, not too bad.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
09-25-2014, 05:14 PM | #5 |
I think originally they were a semi gloss black but even a lot of restorers paint them body color.
Even with step pads you might have a hard time keeping people's feet off the running boards at least on the part that doesn't have a step pad. Right after I painted the 48 in the early 80's I went more than one round with my dad because he couldn't get it in his head that I did not want his cowboy boots on my running boards when he was standing beside the truck.
09-25-2014, 06:43 PM | #6 |
I spoke to a hot rodder last week that does high end builds. He said that if I put Rhino Liner in my pickup bed (and in the engine bay and on the running boards) I should tint it with the color that I plan on using for the truck exterior. The intent is not to match the paint, but to tie it in.
On a mildly related topic, do any of you have a means for filling in the pits on the running boards prior to coating them?
http://67-72chevytrucks.com/vboard/s...s10+frame+swap |
09-25-2014, 06:52 PM | #7 | |
Hollister Road Co.
09-25-2014, 08:10 PM | #8 |
""We just did this on a truck. The color match was very good in the bed and the running boards look good as well""
Pictures please - |
09-26-2014, 09:17 AM | #9 | |
As for the color match they can really get very close.
---Shawn Cecil-1953 5 window build thread Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189 |
09-25-2014, 09:05 PM | #10 |
Last build and the current one will have painted to match...once dry I use 3m clear bra tape. Can't see it and 10000 miles on the truck looks good as new
09-27-2014, 02:44 PM | #11 | |
For the pitting you can use POR-15 system or similar, but it does have a relatively small window for top coating with other paint or coatings if its going to be exposed to UV. It is designed to be self leveling.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 09-27-2014 at 02:51 PM. |
09-27-2014, 02:49 PM | #12 |
09-26-2014, 11:04 AM | #13 |
Hollister Road Co.
Here is the inside of the bed. running boards have the same texture. its a one stage urethane bed liner from Sherwin Williams. Its actually a better match than the picture. Flash seems to make this paint look whiteish
09-26-2014, 08:26 PM | #14 |
"" its a one stage urethane bed liner from Sherwin Williams. ""
Would you happen to have the S W product number ? Locals here only deal with house paint...... |
09-26-2014, 09:40 PM | #15 |
Hollister Road Co.
09-27-2014, 01:25 PM | #16 |
stupid question probably but can it be sprayed with out thinning? If not, what do you use as a reducer?
09-27-2014, 06:02 PM | #17 |
Hollister Road Co.
10-01-2014, 05:58 PM | #18 |
"These are the "Real Deal". They are the ones provided by Chevrolet and GMC truck dealers for the 1947 through 1955 years. Their rough surface was to help prevent a person with wet shoes from sliding on the metal boards. No doubt careless people often broke limbs sliding on a slick wet running boards! Sold pair. Made in USA!"
Just installed these this week. Very good fit. There are six threaded studs welded on the bottom and they provide the nuts and washers. I put a bead of silicone caulk around the bottom to keep water from getting underneath. They work great. There's a link above in my first post to the website. Here's a pic.
I don't have a bucket list but my "F....it" list is a mile long. http://67-72chevytrucks.com/vboard/a...1&d=1411272730 |
