Locking Glovebox
Does anyone know if and when it was an option? Mine doesn't have it, and its a fully loaded Sierra Grande, but I feel like I've seen it on other trucks.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() Join Date: May 2010
Re: Locking Glovebox
I've never seen it listed as an option. My top of the line 69 CST didn't come with one, even though it appears the mounting provision is there.
The Older Generation
To the best of my knowledge they were dealer installed, and/or by a locksmith, after the fact.... LockDoc
Moderator
![]() Join Date: May 2007
I thought it was part of the custom comfort and convenience package or something like that? My 72 super had one when I got it and it is keyed to match the ignition and door locks, and I have pulled several from trucks over the years. I dunno, but it's nice to have.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#5 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
LockDoc has keyed two to match the ignition in my K5 and K20, a nice add. Look for the locking dealer installed gas cap to go with.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Old member
I don't know about the key lock but I would give anything to have a handle on the cylinder to open mine with. No I don't want a gate handle on it either.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
That's a good point Andy! I would love to have a handle as well. Has anyone installed a lock (with a handle) from another vehicle? Pics?
The spring should pop it open when you push the button if it is not missing or broken.... LockDoc
Moderator
I have found that replacing the little bumper stops helps "pop" the door open. If they are missing or rotted the door usually just stays closed unless you use your other hand to pull it open while the button is depressed. The new stops help make the door latch tightly so there is some pressure to pop it open.
#10 | |
Hey LocDock, Thanks for the tip with the spring! I will check it, BTW.. If I find a locking glove box button, can a locksmith make it match my ignition switch from the key alone? Thanks |
#11 | |
![]() LockDoc
Old member
Well mine has new bumpers new cardboard and it want open without both hands.
I don't have any glove box locks at the moment but I can re-key one to match your ignition if you find one....
LockDoc
#15 | |
Here is a nice deal on what I think is an aftermarket set-up for both doors, ignition lock, and glove box lock with keys. I think I might get this for my 68 as I have no keys for it just start fresh with new stuff. http://www.ebay.com/itm/67-68-70-71-...item5893e4494b |
#16 |
I bought a glove box lock as well as ignition and door locks as a set, so they all had the same key. Mine already had 2 different keys for the ignition and doors, so I spent $40 and replaced them all. Not the cheapest way, but I never like not knowing who may still have keys to my vehicle.
#17 |
I have always loved the idea of locking a cardboard box.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#18 |
#19 |
#20 |
Keep in mind that's 95% of the battle. If someone's willing to rip apart your dash, even if its only cardboard, they wouldn't mind prying the door open.
