Old 09-25-2014, 11:55 PM   #1
buckroseau
Engine guru's, need help, what do I have?
Hi,
New guy here. Picked up, what I was told is a 1962. Bit of a barn find. It's been sitting since 1981. Currently is running, not well, but running.
It has an exhaust manifold leak, so I would like to replace that and get a new exhaust welded up before I really start tinkering with the dizzy and points.
I think it is a 3/4 ton, has the 8 bolt hubs. Just wondering what engine I have. Not sure how many options these came with, but I thought I read some where it was at least 2.
Any help would be greatly appreciated. Attached a couple pics from Sunday when I trailered it home.
Thanks in advance, Matt
buckroseau is offline   Reply With Quote
Old 09-26-2014, 12:40 AM   #2
T and S
T and S's Avatar
Re: Engine guru's, need help, what do I have?
Should be casting numbers near the distributor. They will tell you what engine u have. Plenty of charts on these forums that will give u that info.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 09-26-2014, 08:37 AM   #3
1963c-10
1963c-10's Avatar
More than likely its the 235
1964 Short bed trailer
Old 09-26-2014, 10:56 PM   #4
buckroseau
Based on that pic / page you posted looks like it's the only option for an inline 6 for 1962?
Matt
Old 09-27-2014, 06:13 AM   #5
luvbowties
luvbowties's Avatar
Smile Re: Engine guru's, need help, what do I have?
Matt
...as long as no one's been fingering under the hood in the past 52-53 years...
Enjoy that new barn find, buck, & consider yourself fortunate!
sm
luvbowties is offline   Reply With Quote
Old 09-27-2014, 07:06 PM   #6
buckroseau
Did a little pressure washing on the engine today, this is what I'm seeing.
Above the starter: CON4 L261
Behind the Dizzy: GM and what below that looks like l8?
In front of the Dizzy: 3769716
Vin # on the cab card in the visor is: 2C254J110783
Not sure if I have everything or what any of this means?
Matt
Old 09-26-2014, 09:48 AM   #7
MitchFloyd
MitchFloyd's Avatar
Nice! The 235's are my favorite out of all the inline 6's. If you get a chance, I'd like to see some pics of that fuel pump / filter sitting there. Oh, and hang on to them hubcaps! They don't make re-pops for the '62 year hubcaps.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 09-26-2014, 10:54 PM   #8
buckroseau
If the hubcaps have some value they may be for sale, along with the wheels. I'm going for the new / old school rat look.
Hoping to bust out the pressure washer Sunday and get the crap off the motor so I can see the #'s. I will take some more pics then and post up.
Matt
Old 09-28-2014, 01:26 PM   #9
61K10
61K10's Avatar
3769716=235 built Dec 26 1961
search the web--
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-28-2014, 06:59 PM   #10
awbrown
you have a 235 more than likely ... http://1954advance-design.com/Stoveb...g-numbers.html
awbrown is offline   Reply With Quote
Old 09-28-2014, 08:30 PM   #11
Revelation
Revelation's Avatar
That is a sharp looking C-20 best of luck with that truck I can not wait to see what you do with her.
Oklahoma 60-66 Chevy/GMC truck facebook group
Revelation is offline   Reply With Quote
Old 09-28-2014, 11:23 PM   #12
buckroseau
Thanks for all the help guys!
Took a few pics today. Last week I picked up a set of 22" rims with 305/45's on them for $300. Pretty good deal and worth a try. Bolted them on today, I thought they looked pretty cool for that rat rod look. Hoping to lower the torsion bars up front. Also heat the rear coils with rosebud tip and settle the rear down 2 or 3".
Pressure washed the motor to get the casting #'s, took a few pics. Also a couple of the interior. Had a seat cover on it that was all ripped up. Pulled that off and underneath it was the original seat with no rips or tears.
I put in a new set of plugs today, that seemed to make a huge difference since the ones that were in there were from pre 1981 and one was a lawn mower plug.
Ordered up an HEI dizzy and wires tonight off fleabay. Also an intake/exhaust manifold gasket set. Hoping to get those in next weekend. Would also like to get a local guy to bend up an exhaust for it this week as well.
Matt
