Old 09-26-2014, 02:52 AM   #1
Rat65
Nardi steering wheel on 65 gmc?
Anyone know what kind of hub i could use?
Any suggestions? Thanks !!
Rat65 is offline   Reply With Quote
Old 09-26-2014, 01:49 PM   #2
slepysal
slepysal's Avatar
Re: Nardi steering wheel on 65 gmc?
not trying to be a wise guy , but ...... A nardi hub ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-26-2014, 02:33 PM   #3
zplightning
I dig it! I put a Grant steering wheel in my truck with a quick release (I liked the Nardi style but this was more in my price range), so I had to screw around with a ton of different adapters and such. Here's a link to some pics:
http://67-72chevytrucks.com/vboard/s...d.php?t=637309
I started with a Grant 3-hole hub (which should be really easy to find for a C10) that goes on the spline.
From there you can get a 3-hole to 6-hole adapter depending on how many MM apart the holes on the steering wheel itself are. There is a company that sells adapters called Forever Sharp on eBay that I got mine from - an example here:
http://www.ebay.com/itm/0-5-Hub-for-...-/311058032839
I would measure from the column to where you want to wheel to be, to make sure it sits out far enough - and get the proper sized adapter. Mine ended up working out pretty well but did have to exchange a few parts here and there. Good luck!
zplightning is offline   Reply With Quote
Old 09-26-2014, 02:27 PM   #4
padresag
you could have one made. here is a link to one that was made for the wheel. I made a dash for a Morgan that was put on a 2002 Honda S2 chassis and running gear. the horn cap even had the Morgan insignia put on it
http://www.sawmillcreek.org/showthre...r-dash-project
ron
padresag is offline   Reply With Quote
Old 09-26-2014, 05:39 PM   #5
Snailed
Snailed's Avatar
ron
Props to you and the shop building the car. Nice work
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 09-26-2014, 10:40 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
http://www.thefind.com/cars/info-nar...el-hub-adapter
DPowers is offline   Reply With Quote
