Old 09-26-2014, 05:30 PM   #1
paintman
Anybody using an electric fuel pump on a 250 or 292?
Hey guys! I'm considering using external electric pump on my warmed over 292, lumps, cam, etc. Was wondering if anyone one has a recommendation of what pump to use.
paintman is offline   Reply With Quote
Old 09-26-2014, 06:08 PM   #2
casper71
Re: Anybody using an electric fuel pump on a 250 or 292?
I was running an electric fuel pump when i had the 292 in my truck. Ran great, make sure your fuel pressure is around 5psi. I am now running a 8.1 vortec in my truck using a bosch fuel pump at around 50psi.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 09-27-2014, 06:41 AM   #3
luvbowties
luvbowties's Avatar
Smile Re: Anybody using an electric fuel pump on a 250 or 292?
Sometimes converting to things like electric pumps vs. mechanical, and to electric fan cooling vs. mechanical blades off the water pump, just add to the # of things that can go wrong--plus make replacing a troubled one a bit more of a headache.
Just things to consider if changing when not necessary, like when I had to install an electric pump on my '66 due to engine having no provision for a mechanical.
That warmed over 292 really sounds like a bunch of fun. Properly built and with right combo of mods really make them sound AND perform great. No other sound comes close to a "split manifold" on a 6-banger; so sweet!
sam
luvbowties is offline   Reply With Quote
Old 09-27-2014, 11:21 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Pending on the carb....use an electric pump with no more then 8 psi. I'm running one on my mild 292 and it runs great...quicker start ups....easier on the battery. Most of the time a mechanical fuel pump will go out before an electric one will.....especially if the pump is placed as near to the tank as possible. I have my electric pump right under the tank...so most of the time its pushing rather then pulling....which makes them last a whole lot longer.
