Old 09-28-2014, 10:13 AM   #1
Freddy67
Shorten steering column question
Recenty I asked and recieved a lot of helpful info on shortening my steering column on my 67 C-10. i want to try it, but want to be SURE:
I have a manual 3 on the tree column. Will shortening it affect the shift linkage?
I understand the shortening process but dont see any info about that.
Any advice is appreciated!
Freddy67 is offline   Reply With Quote
Old 09-28-2014, 07:04 PM   #2
hugger6933
Re: Shorten steering column question
First off welcome to the site. I have done a shortening cause I was a bigger man than I am now. I recently have loss a 100 LBS since the last time I was in my truck, I had added a tilt and a shortened it to help give me a little more room. I am 6foot 3 inches tall also so I NEED room but I have not done one nor have I heard of one being done on a 3oot truck. I have a 5 speed plan in place for the build I have going for the truck that is a 3 speed[ I have 3 builds ongoing]. For the column I took a van column and "shaved" the shifter hump and filled it and then welded the inner shifter tube to the outer in the park position then cut off the shifter ear. I then welded the little hole for the screws on the shift indicator and then once everything was smooth I primed it with high build primer to paint the int. color of the truck so I can have a floor shift tilt column. It is the only one of the three that will be small block or man. trans so I liked the thought of the 5 speed in it. I am taking two T-5's to make the best shifter location[Camaro and S-10]. Anyways enough about me sorry to ramble.
I think if you were to shorten yours you will need to readjust your shifter rods at the top of the column. Jim
hugger6933 is offline   Reply With Quote
shorten steering column
