09-28-2014, 12:06 PM | #1 |
k5 2wd rear diff
i was wondering if a 12 bolt 2wd rear diff in a k5 is the same width as a 12 bolt 2wd diff in a truck?mine is leaking at the plug welds on the axle tubes,has anyone sealed theese welds?thanks for your info.
09-29-2014, 08:15 AM | #2 |
I know the pieces fit
Re: k5 2wd rear diff
They're the same, but if you pull yours I'd try to seal it. Short of getting it welded up, wonder if POR would stop the weeping?
09-30-2014, 04:35 PM | #3 |
Does it drip or just seep oil around the plug welds? I think most of them have oil/dirt around them. Unless it actually drips I don't think I'd worry too much. You might replace the vent assembly, carb clean the plug weld and then lay the paint to that area thick.....
09-30-2014, 11:25 PM | #4 |
thanks for the replies.i will pull the diff out and clean it up and go from there
