09-30-2014, 03:18 PM | #1 |
Trailing Arm bushings
I am ready to do some work on my chassis and want to replace the trailing arm bushings. What are you guys using and where are you getting them? I saw a kit that had reinforcing plates and bushings but they were polyurethane and didn't look to have the outer metal shell that you press into the trailing arm. How does that work?
09-30-2014, 03:24 PM | #2 |
Re: Trailing Arm bushings
You reuse your original shells with the polyurethane bushings. That's what I have but not installed yet.
09-30-2014, 05:20 PM | #3 |
bought some of the rubber ones from lmc,
09-30-2014, 05:30 PM | #4 |
Keepin an eye out
Heres a question...How do you know when they need to be replaced?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
09-30-2014, 10:21 PM | #5 |
I am doing a frame off so all my bushings are being replaced.
10-01-2014, 08:29 AM | #6 |
I replaced mine this summer with ones from LMC. Mine looked to be original and were dry rotted and cracked. At the same time I did new coils, shocks, CPP front stabilizer bar, new u-joints and carrier bearing, and a CPP rear track bar. Drives great but with all of that at once I couldn't tell you how much of a difference the trailing arm bushings actually made.
10-01-2014, 08:52 AM | #7 |
Prestige Worldwide
I just did this with the Poly bushings, getting the old ones out can be tough since you have to leave the outer shell. I drilled several holes through the rubber, then pushed them right out. I put the Poly bushings in the freezer for a bit, then put the lube that comes with them on and they slide right in.
10-01-2014, 03:25 PM | #8 |
I got mine from travis at azproperformance http://www.azproperformance.com/Prot...lls-7-301.html
10-01-2014, 08:19 PM | #9 | |
3001 N 35th Ave, Phoenix, AZ 85017 http://www.performancesuspension.co... (602) 272-4085 It seems I had the most trouble getting the old rubber ones out, don't remember exactly how I did it but I used a wire brush to finish cleaning the inside of the old existing tubes before installing the new ones into there, they went right with the supplied lubricant. I did them with the truck fully assembled with the axle tubes on jack-stands, I loosened the U-bolts on one side at a time and dropped the trailing arm just enough for clearance one at a time and had no problems at all. I had my come-along and bottle jack at the wait, but not needed. I HAVE HEARD since then that once you loosen those U-bolts that you need to replace them. I have not, but since I heard that it's on my to-do list. I only drive it to the dump, I know, no excuse but I'm not as young as I used to be and not as energetic. The old bushings, after some 250,000 miles, were still good. The new bushings are nice but if I told you I could tell the difference I'd be lying. |
