Old 10-01-2014, 12:40 PM   #1
love trucks
Question 62 1/2ton automatic trans what rearend ratios??
62 1/2 ton automatic trans what rearend ratios came stock? and they are front chunks are they the same as 55-57 chevy passanger cars?
love trucks is offline   Reply With Quote
Old 10-02-2014, 12:32 AM   #2
Captainfab
60-66 Nut
Re: 62 1/2ton automatic trans what rearend ratios??
You might be lucky and have 3.38 gears, but most of the '55-'62 trucks had 3.90 gears. No the Eaton HO32 is not the same as the '55-'64 car differential. The Eaton HO32 was used from '55 second series thru '62 in the 1/2 ton trucks.
Old 10-02-2014, 02:17 AM   #3
GVDobler
GVDobler's Avatar
62 Impalas had 3:08 with automatic and 3:36 with 3 on the tree.
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 10-02-2014, 10:59 AM   #4
Old Truck Man
Old Truck Man's Avatar
??? and just what does that have to do with the truck rear ends????
Old Truck Man is offline   Reply With Quote
Old 10-02-2014, 06:11 PM   #5
GVDobler
GVDobler's Avatar
Just a reference. Some people just absorb info. Not you apparently.
Jon S
Las Vegas NV
Old 10-03-2014, 11:46 PM   #6
66Submarine
66Submarine's Avatar
Actually, I think that statement only applies to cars with the 250HP 327...
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-02-2014, 11:45 AM   #7
66Submarine
https://gmheritagecenter.com/docs/gm...olet-Truck.pdf
3.90 or 4.11. 3.38 was only available with a manual trans.
Old 10-02-2014, 01:21 PM   #8
61K10
61K10's Avatar
anybody ever seen a 3.38 from the factory?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-03-2014, 08:37 PM   #9
love trucks
Thank you. I was told I can check the ratio by somehow marking the tire and the trans mission yoke and turn tire. not sur of the process if you have any info that would help please send.
Old 10-03-2014, 11:12 PM   #10
Captainfab
60-66 Nut
Why not just pull the cover and have a look. I almost guarantee that the oil needs changed. It'll just cost you a cover gasket, a couple quarts of gear oil and a little time. Then you'll know exactly what gears you have and the peace of mind knowing that your differential has fresh oil and what the condition is inside.
Old 10-07-2014, 01:14 PM   #11
love trucks
No cover it is a front chunk rear end.
Old 10-07-2014, 10:46 PM   #12
Captainfab
60-66 Nut
The '55-'62 Eaton HO32 differentials have both a removable 3rd member and a rear cover.
If it doesn't have a removable rear cover it is not an original differential to your truck.
