Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-01-2014, 05:04 PM   #1
TexasLS1
TexasLS1's Avatar
Air Compressor hard starting?
I've had a Craftsman Pro 27 gallon compressor for about 2 years, and I'm having trouble with it cycling. It runs fine initially, but it struggles to crank over on the second or third cycling (the motor will hum like it's trying to turn over, until it kicks the breaker or I shut it off). It has not been through any hard use, and is not used very often, so it looks like I bought it yesterday. Unfortunately it is past its warranty period What do ya'll think, will I be buying a new motor, or is there something I can do to help ease start up? I'm a little frustrated to have a basically new compressor that won't work reliably, and wish I could have gotten this handled while under warranty.
TexasLS1 is offline   Reply With Quote
Old 10-01-2014, 05:43 PM   #2
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Re: Air Compressor hard starting?
Check the capacitors on the motor first.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 10-01-2014, 06:23 PM   #3
Koffer
Also check the unloaded valve to see if it's sticking closed after it up to pressure as it bleeds pressure off the compressor head so it will start easier the next time
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model )
Koffer is offline   Reply With Quote
Old 10-02-2014, 09:17 AM   #4
ERASER5
ERASER5's Avatar
Next check the check valve that prevents tank pressure from back washing into the head. The unload valve (if working) will continue to his until the tank is empty in off mode. The check valve is not really visible. That big nut that the compressor line attaches to is the top part of the check valve.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-02-2014, 06:27 PM   #5
TexasLS1
TexasLS1's Avatar
Thanks for the feedback guys!! Tons of help. I'll check it all out and keep you updated.
