ongoing brake fluid leak
on my 72 c10 i had a problem with fluid leaking from were the front brake hose is bolted to the caliper,i replaced both front hoses,2 new calipers on the right side and new copper washers,now the right side is leaking again and the left side that was not leaking is now leaking in same spot as the right side,the bolts are very tight,just wondering what i am doing wrong.thanks
Re: ongoing brake fluid leak
I used to heat the copper til it rainbows and then torque the bolts to spec. Boom. Make sure there is no paint on the caliper as well.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I've had that issue a few times. Pop's told me to tighten it 1/8 turn until it stops leaking. Always work.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I am having the same issue on a 1970 Pontiac. The bolts are also VERY tight, much more than the spec. I also had a nightmare getting the hoses to stop leaking on my 72 Cutlass. Are they making the copper washers more cheaply and less effective? I am 64 years old and have been doing brakes since I was 18 and NEVER had problems before. I just put on the washers, installed the bolt, torqued it down and drove away.
When you heat them, do you install while still hot? |
Double up on the copper washers.
I had a disc conversion leak like that once and more washers helped. |
thanks i will try those tricks.
This is happening quite often, it's usually the copper washers, probably not annealed properly. China strikes again. I usually change to a different pair and the replacements usually seal.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
