Old 10-03-2014, 12:35 PM   #1
t4keumbw
rear suspension ????
65 c10 rear suspension. I am in the process of building a 1956 c10. I am installing air ride suspension on the truck and I was looking for someone to answer a question for me.
I am using a 2001 5.3 engine with a few goodies should be around 400 horses when done. Should I use a four link setup or a triangulated four link? Not going to be drag raced much and might do a little twisty turny road coursing. But still unsure about what rear suspension. Any help will be greatly appreciated.
t4keumbw is offline   Reply With Quote
Old 10-03-2014, 12:57 PM   #2
PGSigns
PGSigns's Avatar
Re: rear suspension ????
The truck arms will be fine for the planned use of the truck. For road coursing they will do well. They are used in a lot of pro touring setups and under all the NASCAR cup cars.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-03-2014, 01:08 PM   #3
LVPhotos
LVPhotos's Avatar
Porterbuilt has a rear set up for you. Ride Tech as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-03-2014, 03:01 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Moved this into the Suspension forum as you will likely get better results.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-04-2014, 03:00 AM   #5
andrewmp6
Depends if you want it lowered good or laying frame.I would try to use porterbuilt he has a truck arm kit and a 4 link kit for your truck.And ridetech would be the other company i would use also.
Old 10-04-2014, 08:49 AM   #6
IIGW
I personly like the triangulated as it’s easy to set up, and works. A four link set-up, that’s a bit vague as there are numerous 4-link set ups.
Tri-linked gets my vote. And you can do road racing, burnouts, doughnuts, whatever you fancy.
IIGW is offline   Reply With Quote
