Old 08-13-2003, 10:37 PM   #1
nroden
nroden's Avatar
AntiFreeze in Cab
On the passenger side of my truck on the floor mat anti-freeze has showed up twice now. Once a couple of weeks again and then again on Monday. Its not much. Where is it coming from? I can't seem to find where its dripping down from.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 08-13-2003, 10:42 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your heater core is leaking.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-13-2003, 10:50 PM   #3
Randy70C-10
Randy70C-10's Avatar
Yep, what he said.
Randy70C-10 is offline   Reply With Quote
Old 08-13-2003, 10:58 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That or the extra gallon that is under the seat is leaking.
Old 08-13-2003, 11:16 PM   #5
nroden
nroden's Avatar
Well.. I'll have to get that replaced. Hope it'll hold out on me for a week until I get paid again. I have the money but try to keep my checking account at a good level.
I had thought about that but didn't know.
Nick Rodenberg
Old 08-13-2003, 11:33 PM   #6
Longhorn Man
If it does start to leak more, you can just disconnect the heater all together.
Run the hose from the one fitting to the second fitting...just with no heater inbetween.
you can put it off untill it gets cold out!
Old 08-13-2003, 11:49 PM   #7
nroden
nroden's Avatar
While we're getting ready for winter and all (coming sooner than I think) ......... I am gonna replace that relay or whatever it is so that my fastest fan speed work. Also what allows air to blow through the vents even when the fans and all are off?
Nick Rodenberg
Old 08-14-2003, 02:14 AM   #8
BUXMAN66
go bucks!
that would be the air diverter(sp?) in the fan assembly box down on the floor....should be a flap that lets outside air in/and heated air from the heater core out. prolly a bad cable that lets the flap work properly.....most likely culprit. at least a place to start lookin'....
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-14-2003, 06:31 AM   #9
VTKidder
Set it up like this...out of the water pump, back into the intake.
VTKidder is offline   Reply With Quote
