10-05-2014, 12:54 PM | #1 |
Active Member
Northwest Fabrication Aluminum radiator to grill shell filler panels to fit 67 or 68
SOLD
Northwest Fabrication Aluminum radiator to grill shell filler panels to fit 67 or 68 C series trucks These are a satin finish – when I bought these it was the only option for such an item I could find anywhere. I figured I could polish it or paint it black to match the under hood areas. This is a great way to clean up the unsightly area under the hood, lower radiator temps with better air flow as it blocks heat from the motor from reentering the front of the radiator. Gives a clean finished look to the front of your truck. Even the Good Guys give away C10 is sporting these filler panels. If you are running AC with the condenser in the factory location one panel may need to be slotted to allow the condenser to through the panel. If you moved the AC condenser or are running aftermarket AC you may not need to do this $75.00 delivered to your door in the lower 48- Please remember freight is not cheap for these longer items
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree Last edited by 1968SWBBigBlock; 10-05-2014 at 07:12 PM. Reason: SOLD |
10-05-2014, 01:48 PM | #2 |
So,, what else you got???
Re: Northwest Fabrication Aluminum radiator to grill shell filler panels to fit 67 or
Hey guys, in case you don't know, that is a great deal on those. I wish i was doing a 67 - 68 now, I would snatch these up.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
10-05-2014, 01:59 PM | #3 |
Active Member
Thank you for the kind words
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
10-05-2014, 03:25 PM | #4 |
Since I missed the others. I'll take these. PM me a Paypal addy and I will shoot you the funds.
Thanks |
10-05-2014, 03:39 PM | #5 |
Active Member
Pm sent with Pay pal info
10-05-2014, 07:13 PM | #8 |
Active Member
Sold - these will be sent Monday - I will PM the delivery information - Many Thanks!
10-08-2014, 07:23 PM | #9 |
I got them today. They look pretty good...especially for the $$$.
Thanks!! |
10-08-2014, 08:55 PM | #10 |
Active Member
Thanks I am Glad you like them.
10-09-2014, 12:16 PM | #11 |
Who sells these? I'd like to get a steel pair to paint.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
