Old 10-05-2014, 03:27 PM   #1
slam59
Truck have both a fuel pump and electronic fuel pump?
Just put a new fuel pump under the hood with a full tune up a month or so ago and after seeing cable that no longer is hooked up hanging down I see mounted on the frame rail an electronic fuel pump there with rubber lines connected to both ends. Do these trucks have both under hood and frame rail pumps? Also see a red wire not connected like maybe the dog pulled it off. What would the red wire go to ?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 10-05-2014, 04:00 PM   #2
slam59
Re: Truck have both a fuel pump and electronic fuel pump?
The truck has dual tanks
1974 C10 swb 350
Old 10-05-2014, 04:32 PM   #3
hatzie
Moderator
hatzie's Avatar
Not factory
The TBI trucks had a fuel pump in each tank but no frame rail mounted pumps on the squares.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-06-2014, 07:09 AM   #4
cadillac_al
Ingenious, a primer pump to prime the system after the truck sits for a week or so. I have been debating using an electric fuel pump for years and years because my trucks don't get used every day. I just let them crank and crank until the fuel finally gets to the carb. I don't want to rely on an electric fuel pump though. Now, a primer pump that is used only occasionally could be the hot ticket.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-06-2014, 11:00 AM   #5
Tucson38
So how would the plumbing work on that? Would you be forcing fuel through the electric pump by using the mechanical pump? I assume you'd want the electric pump to be bypassed entirely under normal driving conditions.
Tucson38 is offline   Reply With Quote
Old 10-06-2014, 12:20 PM   #6
Keith Seymore
Keith Seymore's Avatar
I have a tank mounted electric fuel pump (Holley red) on both my '65 GTO and my '74 Chevelle.
I have the electric pump wired to a toggle switch. I use the electric pump during periods of high demand, like during a burnout and 1/4 mile run. The rest of the time I drive around on the block mounted mechanical pump and it simply draws through the electric pump.
Been set up that way for 50 and 41 years, respectively. The GTO goes 12.20s at 120; the Chevelle has been 9.80's at 136mph.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-07-2014, 10:10 AM   #7
slam59
I happened to notice it while under the truck on passenger side. told my mechanic about it and gonna let him look at it over the weekend. Has a red wire that looks like it was pulled off or snagged by one of my dogs that lays U see the truck once in awhile. We shall see
1974 C10 swb 350
Old 10-07-2014, 12:34 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
my 79 had one "hotwired" in up front,by the PO
said it was hard to start after sitting week
but turn key and never stopped pumping.
found the 1/4 return line seemed expanded/split.
found splits/breaks in other lines.(red area in 3/8 carb base/charcoal line
repaired to manual only and better now.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-07-2014, 05:42 PM   #9
hatzie
Moderator
hatzie's Avatar
Typical for trucks that are "loosing the prime" in the fuel system. The electric fuel pump is a bandaid on the leaking fuel lines.
I use an electric fuel pump to prime the 1990's 6.5L Stanadyne fuel filter system on my '76 & M1008... it's on a Y off the main fuel line with a shutoff valve on the filter. It's there for priming when changing the filter not used otherwise.
Old 10-07-2014, 09:41 PM   #10
cadillac_al
K
That sounds like a good set up Kieth, nice ET's too. I assume by "tank mounted" you mean mounted near the tank, like on the frame or something near the tank? Those Holly Red pumps are the only ones priced reasonable. I don't know why electric fuel pumps cost so much.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 10-08-2014, 07:39 AM   #11
Keith Seymore
Correct; either on a small bracket or on the "waterfall" of the trunk floor itself.
The fuel supply line comes out of the tank, through the electric pump and then on up the frame rail to the mechanical pump.
K
1979-1986
1986 - 2019
